Question about Samsung Highlight Cell Phone
My phone does not want to charge wats wrong - Samsung Highlight Cell Phone
  • 3 Answers
Try with other charger.. if nt working den make sure d chargin pins on phone s proper... its a small hardware issue.. open d phone n make sure d charging socket on circuit has no damage... ( switch off ur phone n try charging too )
Posted on Jan 03, 2011
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
My phone is stuck on the screen where it asks me for my puk code and im not sure wat it is!
If you need the PUK ( Personal Unblocking Key ) for your phone, you will have to contact your mobile phone service provider.
PUK code is related to the SIM card you are using and not the phone. The phone asks for PUK code if a wrong pin code is entered.
So, kindly call the Customer support of your mobile service provider and they will provide you with the PUK code free of charge.
Also, entering a wrong PUK code ten times in a row disables the SIM card permanently. So, please be careful while entering the PUK code.
Hope this solves your problem. Thanks for using FixYa.
Sep 22, 2010 | Cameras
My sony ericsson w595 phone is not charging it is not the charger its the phone wat is wrong with it
If you're sure its not the charger i.e you've tried another one and you have no voltage issues and there's nothingelse your not telling, you might need to give it up for a charging port change.I would'nt advise you do it yourself, but you could try looking at the charging port and observe if any of the connectors need some straightening out.Then try charging again.
Sep 21, 2009 | Sony Lands Phones
Hii i get some sound in key pad while pressing keys. did it effect anything if i press key long time and hard .wat the reason .and to take care of my mobile wat i should o.plz help me
If it a click sound then it is the key being pressed in the wrong direction. It will effect the key in the long run if you press the keys hard. remember that it is electrnic and not mechanical. If you make the contact slightly the work should be done. Pressing it hard does not mean that you can force it to do something that it cant or does not want to do. To take care of your phone, keep it clean, use it gently, dont throw it around even on a soft surface, avoid humidit, if it gets wet remove the battery immediately and dry its insides with a hair dryer and use it only when you are sure that it is dry. Paste a scratch guard on its glass. Keep its battery fully charged, dont run it on low battery. If it gives you the signal for low battery, put it on charge.
Jul 29, 2009 | Nokia 6300 Cellular Phone
Phone won't turn on.
Back to the retailer, it's screwed =/
Jul 15, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Screen?
there is problem with ribbon of ur phone, or screen itself. as u said u have charged ur battry so no doubt there is nothing wrong because of power. there is problem with ribbon of ur phone, which has caused fault may be because it got pressed under u while sleeping, better u take it to technician.
Feb 23, 2008 | Motorola Mobility E815
LG SHINE
Did the "charging" icon appear on the screen? If not it sounds like the mini usb port on the phone is not working. Bring it back and get a replacement phone. But, make sure you didn't accidently plug it in wrong first. It will go in upside-down if you force it (at the phone-end of the cord). Wouldn't want that hanging over your head.
Dec 22, 2007 | LG Shine KE970 Cellular Phone
Samsung Highlight  Cell Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
