Question about Ricoh Office Equipment & Supplies
How to solve error SC452 for colour copier - Ricoh Office Equipment & Supplies
  • 126 Answers
Sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Posted on Jan 05, 2011
    New Friend:
    Problem Solver:
  • 12 Answers
SC452 is a 'paper transfer unit contact motor error'. Reasons for this error could be a defective contact motor, defective contact sensor, defective IOB or an open 24v fuse in PSU. I would do an input check for the sensor, an output check for the motor and replace them accordingly before replacing the IOB that is more expensive. Good Luck!
Posted on Mar 24, 2014
2 Suggested Answers
joel_baleta
  • 155 Answers
SOURCE: Ricoh Aficio 3006 error sc452
SC326, First of all check that the laser slitglass is still there, I've seen a couple of machines where the slitglass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
Posted on Sep 23, 2011
Tip
What to do if your ricoh 1022/1027/270/220 copier show SC452
To who had encounted this problem:
1. Don' t panic as the copier jammed temporarily
2. Switch off the copier
3. Open the lateral door,take out the fuser unit & replace the 2 unit termistor unit with the new unit [cost around us30]
4. Insert back the fuser unit then closed the laterl door
5. You have to reset the copier, below is the process:
6. Switch on the copier
7. Push button cancel[yellow] with button 1, 0,7 then follow
on Apr 16, 2010 | Office Equipment & Supplies
Ricoh sc452
That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
Oct 24, 2013 | Office Equipment & Supplies
HOW TO REPAIR CANON IP2772 ERROR 5B00
In your Printer colour curtize is blank. please refil. then try it will come back.
Oct 04, 2011 | Office Equipment & Supplies
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
SC452 Transfer Belt Mark Detection Error
Without the model i think it is difficult to help you any way.
Mar 05, 2011 | Ricoh Office Equipment & Supplies
Error 05 colour ink light flashing
Use only original cartridge to solve this error code.
May 25, 2010 | Office Equipment & Supplies
Internet Explorer script error when printing for
Try to repair windows and problem will be solved .
good luck
Oct 10, 2009 | Lexmark X6675 Pro Colour Wireless...
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
3,298 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
