Question about GPS
Have recently purchased used car fitted with a remocon lrt 1 car alarm car battery was changed would like to know how to reset alarm & remote door locker. can you be of assistance?
  • 64 Answers
SOURCE: I do I reset the alarm/door locking system
there could be a problem with the actual remote, get it checked, if you do need a remote plz get it from a mercedes main dealer.
Posted on Feb 17, 2009
SOURCE: Don't know the radio reset code. Is there a factory reset?
You need to call an Audi/VW dealership and have the auz code off the back or side of the stereo, which means you have to pull out the stereo. Also you have to give the dealer your VIN # and then they can look it up for you. They may try to tell you they have to hook it up to a computer, thats BS! They will try to get you to bring it in. You have to know what you are talking about when you call, or they will give you some lame excuse to get you to bring it in. They are required to give it to you for free if you tell them the radio code isn't in the owners' manual given to you with the car.
Good luck.
And search through the audizine.com forums or any other audi forum, it will tell you what you need. You may even be able to get someone who posts on the forum and works at a dealership to look it up for you, if you ask nice.
Posted on May 15, 2009
mcgyver468
  • 710 Answers
SOURCE: Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
Posted on May 18, 2009
SOURCE: my jaguar x-type 04, remote lock does not work,
I have a similar problem in my x type. Although if I press unlock button on the key first and then use the metalic key to unlock it dissables the alarm.
Also according to the manual if you unlock by the metalic key the car starts a beeping sound its I think 15-20 second timer within which you should put the key and start the ignition (don't need to start the engin) this will dissarm the alarm if not the alarm will go off in 15-20 second.
Hope this information is of any use, am trying to get hold of Jaguar dealers to fix this issue. If you come accross any solution please do let me know too
Posted on Aug 03, 2009
  • 521 Answers
SOURCE: 2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Posted on Aug 13, 2009
Doors wont lock, security system wont set while using alarm remote?
Is the remote battery dead? Or have you recently changed the battery in the remote?
If the first it needs a new battery.
If second. You may have taken too long to change the battery and the remote is no longer programmed to the car. you will need to take it and the car to it's dealership and have them reset it. It will cost.
Oct 29, 2013 | 2005 Honda Odyssey
I have a 1999 Acura and my wife is trying to change battery for me while I am deployed. The alarm keeps going off and the remote will not shut the alarm off. How do I change battery and keep alarm from...
the easiest way might be to use a set of jump start leads & connect them to the new battery, then to the battery leads of the old battery before you disconnect them from the old battery,then remove the old battery & fit the new one being careful not to dislodge the jump leads then put the battery leads on the new battery.....hope this helps......cheers.
Aug 31, 2011 | 1999 Acura TL
The car alarm goes off every time I open the door. I changed the battery in the remote car door opener but it never worked. What can I do?
because of the variations in remotes fitted, i can only suggest you reset the alarm for you particular alarm system.
Aug 25, 2010 | 2006 Chevrolet Cobalt
I have a 1997 Toyota Camry. Recently, the security alarm malfunctioned, blaring the alarm and the remote control on the keys wont deactivate the system even after changing the batteries on them. I recently...
You need to reset the alarm by inserting the reset key(small plastic devise with visible contactors that should be with the keys) for a few seconds in the it's hole in the right-hand rear speaker. Open the boot look at the underside of the rear right-hand speaker to locate the hole.
Jul 03, 2017 | 1997 Toyota Camry
AFTER CHANGING MAP SENSOR FOR MY 2001 CHRYSLER TOWN &COUNTRY VAN JUST RUNS FOR A FEW SECOND AND THEN DIES OUT WHAT WOULD CAUSE THAT PROBLEM
try reseting the immobiliser/alarm or fitting new bateries to the remotes then reseting as a first step.(i am assuming you disconnected the battery to fit map sensor)
Jun 14, 2010 | 2001 Chrysler Town & Country
Car alarm going off after replace positive cable
If you do not have the remote control for the alarm (which can sometimes be purchased on ebay) You will have to uninstall the alarm.
The alarm is wired between the ignition coil wire coming from the ignition switch if the car is turning over and just wont start.
This can be complicated because of the amount of wiring, You have to cut the alarm wires out 1 at a time and match the cars wires back together.
I just did this for someone on a toyota recently and you really have to pay attention or put a peice of tape on each wire writing the color for example(white wire with rd stripe or white wire with red stripe ect.)
I hope this helps you,
Please rate me if this was helpful,
ETRONIC
Mar 14, 2010 | 1994 Saab 9000
Car remote not working
Sounds like you need a remote, or the remote lost its program. You need to check at the dealership to be sure.
Aug 28, 2009 | 2002 Pontiac Grand Am
May 18, 2009 | 2007 Mercedes-Benz ML350
My battery died after recharging it the alarm buttom needs to be reset. I need to know where the reset buttom is
HI ! I haven' t researched your car for you just yet !
I thought Id quickly mention the common method for reprogramming your alarm & remote, If you still require assistance then just ask me and I will find more about your car :)
Common Methods for resetting/re-learning code
  • Factory Fitted Alarms/ Central Locking / remote comes on ignition key.
Insert ignition key , turn key to accessories / red , press & hold lock/unlock for a few secs.remove key,exit vehicle and try un/lock doors &/or alarm (Some models differ slightly & require engine on or manual use of door locks whilst resetting.
  • Aftermarket /Non-Factory / remote is separately operated
Most use a small back-up battery usually located within the loudspeaker/Alarm unit itself under the bonnet,
Remove this battery for a short period to reset the remote code
The access panel for the backup battery is never in an obvious place. look carefully :)
Jul 14, 2008 | Hyundai Sonata Cars & Trucks
GPS Logo
162 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
