Question about ASUS Computers & Internet
My monitor is of AOC " e2043Fsk " . When I try
  • 5 Answers
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Jan 03, 2011
How can i change AOC monitor to wide screen, menu bar does not highlight. I have three monitors and the one on display port is wide screen by itself.
go into the computer , control panel find the appearance and personalization section ans change the aspect ration of the screen there. don't forget to apply and save(ok) before leaving
Feb 13, 2015 | AOC Computers & Internet
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computers & Internet
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
Display Problem on AOC Monitor
Does it blink very fast?
To test if it is the monitor try it on another computer.
Trying to resolder probably made it worse a part needs to be changed and might cost more than a new screen lol.
May 13, 2009 | Pc Ware Computers & Internet
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
Computers & Internet Logo
1,147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
