Question about Neff Dishwashers
Water leaks into bottom tray when filling
Please help. when filling with water the dishwasher leaks water into the bottom pan.After about two complete washes the float swich operaters and then it stops mid cycle.Thanks Ashley Battison
  • 190 Answers
Dear batties,
Such water filling problems can be generally solved by checking the following
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Also for the mid cycle problems check the following
hope u find this useful. thank you for using fixya.have a great day.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Error code 01 keeps coming up and will not let dishwasher complete its cycle. My dishwasher no. is ewdw6505gso and it is only 3 years old. I have 2 other appliances that are Electrolux. Please help.
Mine was only a few months old when error 01 arrived - it is a leak. The Electrolux dishwashers have a leak detector at the bottom inside the plastic pan, that when water appears it sets off the code and you cannot restart the dishwasher until you dry the pan out (tip the unit forward and water will come out) but it will keep on doing it unless you repair it - mine was covered under warranty and they replaced a lot of parts at the bottom. Not even a year later it leaked again, but not as bad. I took it apart and removed a fabric pad that sits in the bottom of the pan, it does not go off that much any more since the water evaporates before it does any damage. I think this feature is completely useless - I would rather see a wet spot on the floor than not be able to do dishes... If you got 3 years you are doing well. I will just replace my appliances as they die and never buy Electrolux ever again! PS if a refrigerator is one of your other units, be aware that their main boards can fail and are very expensive to replace. You will know it is blown when your food freezes in the lower compartment and your lights come on instantly instead of glowing up slowly.
Nov 15, 2013 | Electrolux Dishwashers
Display showing f4 what does that mean thank you julie
Hello
Fault with water fill (only on machines with level-controlled fill)
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
Aug 21, 2011 | Bauknecht 24 in. GSF8971 Built-in...
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
D3350 F4 indicator
F4 This is a Fault with the water fill
Note: Lights blinking, pump running and controls dead indicates an over fill fault
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find that it is full of water)
7. The drain hose must run up to the top of the underside of the counter top then down to the drain. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Aug 05, 2009 | Asko Dishwashers
Panel lit and motor running but will not cylce
It's almost certainly the case that something has started leaking in the bottom of the dishwasher (a seal or hose) and has filled the bottom catch pan with water. There is a float in the pan which will trip the unit into a mode where the pump turns on to flush out all the water inside the unit to avoid overflowing the pan and causing much more damage (to the subfloor and anything on lower stories or basement). As long as you have the unit turned on, the pump will run to flush out water. Until the catch pan is purged or enough water dries up.
At any rate, somebody needs to look at why the catch pan is filling up with water.
Jun 01, 2009 | Asko D1776 Stainless Steel Built-in...
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 | Dishwashers
No fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
Sep 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Asko 1605 cycle stopped, pump keeps running, water pumps out but will not progress to the rinse and wash cycles. Timmer will turn and detergen dispenser will open. Pump keeps running
Thanks my Asko did the same and tilted it forward, drained excess on the floor, even though I thought i'd bailed the whole lot and woolaa fixed - thanks x
Oct 18, 2007 | Dishwashers
Dishwashers Logo
240 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
