Question about Mach Speed Eclipse 180 MP3 Player
No matter what we do its stuck on the main screen! its not being registered on the computer when hooked up with usb cord.
Do not hook the mp3 player to the computer until you are in your windows media player or equal program. disconnect it if it has been charging, re connect when media player is active.
Posted on Jan 10, 2011
I try to turn it on nothing will happen my uncle think it is fried
Posted on May 02, 2011
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
How do you hook up cords in a Dell dimension 3000
You just plug them in. Each cord will only fit in it's own spot, you can't get it wrong. There are also USB plugs, those it doesn't matter, any USB device (mouse, keyboard, etc...) can go in any sub slot.
Just plug everything in, you can't get it wrong.
Aug 11, 2014 | Computers & Internet
My phone no longer works with my computer via usb
1)NOKIA 5300 HAVE GIVE TO NEW VERSION SOFTWARE ,& YOU USE ORIGINAL NOKIA PC SUIT & INSTALL IN YOUR COMPUTER.
Aug 22, 2009 | Nokia 5300 Grey Cellular Phone
Camera giving white screen when I try to download to my computer
Pls check the Camera Mode in Menu options it needs to be in PC or toggle in other modes and check if it works otherwise change the USB cable
pls rate me WELL !
Jul 16, 2009 | Fuji FinePix S700 Digital Camera
Computer runs off battery only not the power cord (battery is brand new)
You have a serious problem with the power and charging circuit. Normally if the battery is faulty the laptop can function with the power adapter plugged and running off the mains.
If a techo cannot fix without replacing the motherboard, then replacing the motherboard might not be a cost effective solution.
You salvage the hard drive by inserting it into an USB hard drive adapter case and use it as an external USB hard drive.
Sorry about this, you have very few options.
May 14, 2009 | Gateway MX6447 Notebook
Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Jan 11, 2008 | Garmin nuvi 350 GPS Receiver
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Sansa Sandisk E270 - Refreash Database
I found that the unit needs to be turned on first then plug it into your usb port.
Dec 20, 2006 | SanDisk Sansa e270 MP3 Player
Mach Speed Eclipse 180 MP3 Player Logo
310 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
