Question about Packard Bell iMedia 6826 (P481000502) PC Desktop
Turn on computer, hear beep beep beep. then monitor does not come on, says no signal. looking at black screen only
  • Anonymous Mar 24, 2014
    long steady beep over and over, monitor won't turn on.
    Problem Solver:
  • 16 Answers
3 beeps is usually a memory error. In fact, it means there is a failure within the first 64KB of system memory. You can usually find out if one of your ram sticks is bad by taking a stick out and turning the PC back on. If it boots, you found the bad ram. If not, replace and try again.
Once you can ever get it to boot, you can go to memtest (http://www.memtest.org/) and download the auto installer for USB key and boot from USB (usually by pressing f12 or del, depending on your bios...it will say on boot up). This will tell you if you have any further ram issues.
If this doesn't resolve your issue, the other option 3 beeps can mean is a bad motherboard or other system device (worse case scenario, and fairly rare).
Hope this helps...
Posted on Jan 03, 2011
  • 2,385 Answers
Hello
The three beeps normally due to RAM defect, check the RAM stick if it is placed properly, re-install the RAM module, els replace the RAM.
Hope this helps, if so do rate the solution
  • 232 Answers
Normally this is an sympton of your harddisk crash. But would recommend you to try few steps try disabling few hardware items one by one and then check if the computer boots up like disable CD Drive it that works then the problem is with cd drive. and then graphics card and try the trail and error methods.
Note: Perform the steps only if you are aware about how to remove and add the hardwares back to your computer if not take the computer to the techician who will perform them for you.
Wf1907
problem on computer
1. motherboard damage.
2 ram damage
please open the the ram if you hear any beep please change ram
Jun 28, 2014 | Compaq Computers & Internet
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
Monitor lite is on but screen is completely black
You have a possible hardware problem! Is the monitor light green or amber/red? If it's the latter it's not getting a video signal which means it can be anything from the cable to the video card to the motherboard etc! Do you hear any beeps from your computer or just 1 on start up? 1 beep is normal any more and it will spell out a fault code! More details are required for an accurate diagnosis!
Oct 08, 2010 | Xenon Computers & Internet
When i turn on the computer i get a black screen. I don't get a boot up screen or anything. I have tried unplugging all the drives and dvd players then tried turning it on and i still get a black screen. i...
if you can hear a single beep coming from your computer when you turn it on, try using another monitor? it might be the monitor that is having the problem.
Aug 27, 2010 | Computers & Internet
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
The screen is black and I cant get it to the safe
if you hear no beeps when you boot, you probably just have a bad video card or monitor, or your monitor cable may have come loose....answer back...
Aug 09, 2009 | eMachines EL1210-11 PC Desktop
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
526 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Daniel Florin
Daniel Florin
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
