The heater keeps turning its self off after a few hours
    Problem Solver:
  • 14 Answers
Check to see if filter is plugged? The furnace will shut itself off if filter plugged. Replace filter with one recommened for unit. How long has it been since you had your furnace checked and cleaned? it should be done on an anual basis to keep it running safely and at it's top efficiency.
Posted on Jan 03, 2011
My cuisinart conical burr coffee grinder has started to turn it's self on every few hours
Electronic failure. If you like the grinder, plug it into a plug-in timer that only allows it to run when YOU want it to run. I have a timer like that on my coffeemaker so we don't forget to turn it off & let it run empty all day long. There are cheap timers available that will turn on for three hours if you push a little button, then shut off until next time you push the button. VERY handy, and they give you a selection of one hour, three hours, or six hours. For your purpose, one hour sounds fine. Or a wind-up type timer that stays on for only fifteen minutes, just long enough to grind coffee. Or unplug it when you're done. Or put it on a power strip with a switch.
Aug 01, 2014 | Cuisinart Conical Burr Coffee Grinder
When we turn the heater it runs for about a half hour then hl2 comes on the screen, what does it mean?
check your gas pressure sounds like it is overheating that is a safety so heater will not self destruct
May 25, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
I keep my heater off with just the pilot burning most of the time. When I turn it on (turn up the thermostat) it can take 12 or more hours before the burner lights. After it lights the blower cycles on and...
The Thermopile may be weak and is taking to long to completely heat up to open the gas valve. Or the combustion chamber may need cleaning. Since it seems to work ok, when the front panel is off. Either way, it's best to let a qualified serviceman make those repairs.
Feb 10, 2011 | Empire RH35 Mid-Size Heater
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Mar 22, 2009 | Dell OptiPlex GX260 PC Desktop
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Ice forming daily on freezer bottom
ice build-up on the bottom of the freezer usually means that there is a problem in the self-defrost system. You may even have damaged door gaskets. When you open the freezer door, you also let in a blast of warm, often humid air. This moisture usually freezes onto the evaporator coils immediately. Self-defrost freezers are supposed to self-defrost themselves. Every 6-12 hours they turn off the compressor for a few minutes. A defrost heater then turns on to melt any frost build-up on these coils, which allows the frost and ice to melt, then it drains off to the pan underneath. Unfortunately, though, when a component fails, too much frost can build up on the evaporator coils. With no air flow over the coils, cooling in the freezer compartment becomes almost non-existent.
You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work properly. If your freezer now works the way it's supposed to, test the three other components in the self-defrosting system, the defrost heater, the defrost thermostat, or the defrost timer.
You can visually inspect some defrost heaters to see if there is a break. If it looks physically broken, then it needs to be replaced. Otherwise, check the defrost heater for continuity.
The defrost thermostat, which is just a bi-metal switch, lets current pass through at factory set temperatures. It also prevents current from passing through at the temperatures set by the factory. The set temperatures for the defrost thermostat vary from manufacturer to manufacturer.
You can test the defrost timer by manually advancing to the defrost cycle. You can usually manually advance this timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. The timer should advance out of the defrost cycle in less than an hour.
If, after testing these components, it still does not cool properly, there may be a problem with the refrigerant level and you will need to contact a professional appliance repair person.
Sep 08, 2008 | LG Refrigerators
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
