Question about Ryobi Garden
Does the fuel return line go from the bottom of the carb back into the bottom of the fuel tank
    President:
  • Ryobi Master
  • 1,545 Answers
The return line goes from the side of the carb that has the cover with the vent hole (metering chamber) back to the primer bulb (if primer bulb is external) and thru the bulb and THEN back to the carb. If the bulb is on top of the carb, then the fuel return is in fact coming from the "bottom" (metering chamber) side of the carburetor and to the fuel tank.
Posted on Jan 05, 2011
Where the fuel lines go on a mcculloch 2.0 2014 chainsaw
The return line needs to inserted only about an inch into the tank as it is only returning fuel and not picking up fuel. Note some these return lines on other models have a line coupler on the end to prevent from coming back out.
Feb 02, 2015 | McCulloch Garden
Ryobi mdl RY 26921, the fuel line from the tank - which fitting on the carb does it go on? Top(where the bulb is) or bottom?
The main fuel line from the tank that has the filter in the tank on the end of it will connect to the brass nipple near the bottom of the carb. The top nipple by the bulb is the return line and just sends air/old fuel back into the fuel tank. So, fuel supply line is connected on the OTHER end of the carb.
Sep 02, 2011 | Ryobi Three Trimmer Combo
Bulb on primer collapses. which line in gas tank does the filter go on?two tubes in tank one goes to bulb other goes to bottom of carb which one gets the filter, it fell off
The line that goes to the bottom of the carb has the in-tank fuel filter. That is the fuel supply, the one coming out of the primer base assembly under the bulb is the return line. That line carries air mixed with old fuel back to the fuel tank when the bulb is pushed.
Jun 11, 2011 | Poulan Garden
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Jul 09, 2010 | Troy Garden
Fuel lines
line from the tank with the filter on it goes to the bottom inlet or( depicted inlet) on the carb the top is the return line that goes to the inlet of the primer the other side of primer goes to tank.Primer draws fuel thru carb to tank
If primer is mounted on carb filter line = inlet to bottom fitting= other is return to tank
May 28, 2010 | Garden
Gasline mixup
one line comes directly from the fuel tank (the one with the filter) to the inlet side of the of the carbruetor ( the bottom fitting on the carb.usually)
the other line coming out of the fuel tank is the return fuel line and it hooks up to the outlet side of the two fittings on the primer bulb
the other side of the primer bulb goes to the only fitting left to hook to at the carbruetor.
you have 2 different length fittings on the primer bulb itself
the longer fitting is your return line hook it up to your tank side and the short one goes to carb.fitting
when you get it hooked up press the bulb several times and see if it primes as it should(fuel moving thru lines) from tank thru carb. thru primer back to tank
Jul 10, 2009 | Ryobi Garden
Ryobi 768r fuel line
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer fuel way...
Start from the tank(fuel filter) connect to the filter then to the top of the carb.Top of carb is where the H & L screws of carb is.Then from bottom of carb to primer bulp(**** side)then from primer(blow side)to tank return.
Aug 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
115 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
