Question about Pioneer VSX920 71 Channels Receiver
How do i stop the amp frombeing in pcm - Pioneer VSX920 71 Channels Receiver
At the bottom of the reciever, there is a button labeled STANDARD MODE. Press it and the reciever says PCM. Two buttons to the left is a button marked AUTO/ACL/DIRECT push that a few times and you'll have other options.
Posted on Jun 13, 2011
One of the quick release levers will only open half way stopping the bucket frombeing detached
need more info on which make of truck and bucket in use
so taking a BIG guess
if its a manual release rod or cable adjustment
ad more grease
frayed or stretched cables
if its hydraulic release
faulty lever
lines are low on oil
look for leaks at joints or connections
or a pump problem
Sep 09, 2016 | Cars & Trucks
Where is the ECM located?
How To Change The PCM On A Chrysler PT Cruiser ...
? 14:05
https://www.youtube.com/watch?v=fLN48sAKpiE
Jul 24, 2014 - Uploaded by The Hapless Housewife
How To Change The PCM On A Chrysler PT Cruiser ... things wrong with my car now, but had I replaced the PCM (aka) ECM a long time ago, ...
Chrysler PT Cruiser Engine Computer Module ECM PCM ...
www.ebay.com > ... > Engine Computers
eBay
$169.00 - ‎In stock
Chrysler PT CRUISER Engine Computer Module ECM PCM ECU - "Plug & Play" in eBay Motors, Parts & Accessories, Car & Truck Parts ' eBay.
Dec 30, 2015 | 2002 Chrysler PT Cruiser
What else, Check Engine Light, P0505, p0135, p0155, p1494 codes?
You can not work on a vehicle as your doing
Your checking for generic codes only & throwing
parts at it
You get a couple possible worn or failed parts & have
a few less codes
There is no need to clear ALL Data every time you change a part
You need to STOP
You need professional scan tool software to look at ALL data & go for a road test first
You keep clearing stored data ,so now the process will take longer
You work one code & one system at a time
NO PARTS get replaced that are not tested & found to fail
a test,thus a worn out part.
You need both Factory Emission & Diagnostic Manual, as well
as Wiring Diagram Book-- BEFORE-- you can even walk to the vehicle (Helm.Com)
You have nothing to go by,no system knowledge & no trouble charts,& no wiring diagrams to start your testing
If you got no scan tool & no volt meter & no oscilloscope,
your done,vehicles have to be tested to find a problem,any
problem,resolve it & continue on.
May 19, 2014 | 2004 Jeep Grand Cherokee
Audio output from amp stopped working on 1 input but others fine
you most likely need to assign the digital input "your optical" to a certain input on the amp like tv/sat
Feb 18, 2010 | Sony STR-DH500 A/V Receiver
The stereo just stopped working.
If you remove the pcm there is a small 10a fuse in the back, to remove the pcm remove both centre console side panels and turn the 4 (2 each side) allen screws 1/4 turn, also dont forget a small 6 or 7 mm screw on nearside of pcm that needs to be loosened. otherwise try a software reset by disconnecting the battery with ignition on and reconnecting after a couple of mins. hope this helps
Aug 18, 2009 | 2005 Porsche Boxster
Changed crank sensor and filter in fuel tank still didn't work
Was your mechanic able to pull any trouble codes when the "flight recorder" was connected?
Does the engine run good at highway speeds and bad at idle to off idle?
Let me know.
Regards,
Jul 20, 2009 | 2003 Jeep Grand Cherokee
Tail light are not working
fuses under hood
POWER DISTRIBUTION BOX Location Name Amp Circuits Protected A Trailer Tow 50 Fuse 32/Fuse 26/Electric Brake B Fan (Hi) 60 Cooling Fan (CCRM) C Start 60 Starter Solenoid/Fuse 30/Fuse 36/Fuse 2 D Ignition 60 Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33 E Rear
Blower/
RAS 60 Rear Heater Blower Motor
Rear Air Suspension F Seat 60 Power Seats G — — Not Used H Fan-Lo 40 Engine Cooling Fans J Power Accessory 60 Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19 K Light 60 Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17 L ABS 60 ABS Control/Pump Motor Module M Heated
Backlight 60 Heated Backlite/Fuse 16/Fuse 28/Fuse 22 N Fuel 20 PCM/Fuel Pump/CCRM P — — Not Used R PCM 15 PCM Memory S PCM 30 AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV T Alt./Reg. 15 Generator U Air Bag 10 Air Bag (Dedicated) V Trans. Light 10 Transmission Indicator Light W Fan 10 PCM Fan Monitor X Diode — Hood Lamp Diode Y Relay — RH Trailer Turn/Stop/Hazard Lamps Z Relay — Powertrain Control Module AA Relay — Windshield Wiper Speed BB Relay — LH Trailer Turn/Stop/Hazard Lamps CC Relay — Windshield Washer Pump Motor DD Relay — Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps Color Code 4 Pink 5 Tan 7.5 Brown 10 Red 15 Light Blue 20 Yellow 25 Natural 30 Light Green 40 Orange 50 Red 60 Blue
Mar 14, 2009 | 1997 Ford Windstar
Pioneer VSX920 71 Channels Receiver Logo
175 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
