Question about RCA Televison & Video
Received a RCA 37LA30RQ television for Christmas and the screen constantly flickers and sometime flickers to a white bar across the top when a movie is on. Dish Network is installing a HD dish in a few days so I was wondering if this problem is due to not having a HG receiver.
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
  • 556 Answers
SOURCE: no sound
Sometimess it is the dish receiver have you tried rebooting the dish receiver, hold down the power button on the dish receiver until the picture goes away then turn the button aloose then don't mess with it until the receiver reboots, then see if your audio returns.
Posted on Sep 04, 2009
satavlad
  • 405 Answers
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Posted on Nov 03, 2009
SOURCE: DISH NETWORK REMOTE FOR EMERSON LC200EM8G
I have a LD195EMBZ. I called Emmerson and they told me that they are a little behind on getting current codes. I told him " Just little behind huh, I bought my TV 2 1/2 yrs ago." He laughed (just a giggle), and said, yeah I know, I am really sorry. Not the tech supports fault........Emmerson needs to get on the ball, and do there job. Just my opinion.
Posted on Jan 25, 2010
  • 148 Answers
SOURCE: Philips 47
Hi there, they problem is not in the input to the tv (dvd/cable etc) your powerboard/videoboard is overheating! Right away place a fan as close to the back of the tv as possible, this will help cool the circuits down and might considerably prolong the usefullness of the tv..The next step in it breaking down is total powerloss, or a blinking powerlight, eitherway this is your solution;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not )please rate, thank you!d4195d7.jpg
Posted on Feb 04, 2010
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
I have sound but no picture on my 37la30rq
If you can see a backlight but no picture the problem is T-con board if not inverter board fault..
NOTE: make it sure to turn OFF the lights..
Aug 28, 2012 | RCA Televison & Video
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Asus x83v monitor has a red flickering bar across the lower part of the lcd it is as thick as the task bar thats why i have to place the task bar on the top, its like a static flickering red to pink and...
The display hardware is damaged. Most likely you will need to replace your screen. In rare instances, this can be caused by a loose ribbon connector from the display to the display adapter board.
Mar 29, 2010 | ASUS X83Vm-X1 Notebook
On our Sony BDP-S360 DVD player, when we watch movies it keeps flashing a white bar across the bottom of the screen or flicker of white every once in a while.
you might have a loss connection?
what kind of cable are you using ?
hdmi / component / composite?
unplug the power cord to the ac outlet for 30 secs. and plug it in back. this is to refresh the unit.
turn on fan on the configuration of the unit ...
please read the operating manual ...
Jan 06, 2010 | Sony BDP-S360 DVD Player
When picture has alot of white it shutters and flickers reallybad
My color wheel went out on mine and it looks to be the same on yours'. RCA cannot find a replacement for my model and there are none available on an on-line search. RCA may end up replacing my set.
Jan 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Have a weird problem M50WH74S RCA
i found out tht it could be the (DMD) Digital_Micromirror_Device i dont know if that is you problem or not
Sep 17, 2008 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
89 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
