Hi! I have a Dell Optiplex 755 and need to upgrade the current BIOS of A11 to A17. I run the file and it prompts to a password which is unusual for BIOS upgrade. I checked the BIOS setup and it prompts to unlock BIOS. I do not know the BIOS password. Please help. Thanks Martha
    Scholar:
  • 151 Answers
The optiplex 775 comes in three models...standard tower, mini tower and mirco tower.
the user manual can be found here:
http://support.dell.com/support/edocs/systems/op755/en/index.htm
find the section in the manual that shows you the components on the motherboard. (I browsed it quickly and found one diagram on page 95) Look for the "password reset jumper". this will reset the BIOS password if any has been entered.
if you cannot find the password reset jumper, the other option is to carefully remove the coin cell battery for about 10 seconds or more while your PC is turned off and unpluged. In doing this you will have to re-enter your bios and reset your time and date information so it is a last resort option.
Posted on Jan 03, 2011
Flash bios mdle # opuo52
Select the correct Operating System, and click the down-arrow next to BIOS here... http://www.dell.com/support/home/us/en/19/product-support/product/optiplex-755/drivers
Jul 23, 2014 | Dell Computers & Internet
How to upgrade RAM in a Dell-optiplex gx150 from 512mb to 1gb ?
After installing the new boards restart your computer and it should recognise the new boards and install the drivers for them. They'll have to come from the internet most likely.
Apr 27, 2014 | Dell OptiPlex GX150 PC Desktop
Remove bios password dell optiplex 755
Go here http://www.dell.com/downloads/global/products/optix/en/opti_755_techspecs.pdf and download the file.
Select the correct motherboard for your particular Dell and locate the Password Jumper. There should be three pins in line with two of them connected by a bridging piece.Remove this and put it across to the other pin which is not normally connected. Leave in this position for a few seconds and then return to the original position.
In some computers this removes only the password setting but in others it may require you to re-enter the bios settings prior to boot.
Warning: DO NOT LEAVE THE JUMPER IN THE NEW POSITION WHEN STARTING THE COMPUTER.
Nov 07, 2013 | Computers & Internet
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
I got dell optiplex 755 desktop computer when it is plug tot he current fan run automaticly
The fans will begin to run as soon as the on/off button is pushed. You question is a bit confusing, can you rephrase it?
Dec 27, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I have dell optiplex 755. I am unable to upgrade BIOS, BIOS is needs to be unlocked so I can upgrate BIOS to the latest. Please help.
Hi Martha,
If you need to unlock/reset bios password, here's what to do:
Unplug the pc and remove the cover. Look at the manboard (the big circuit board inside). look for a round silver button cell battery, about 1.5 centimeters wide. Remove the battery from it's socket and leave it out for 1 hour. Then put the battery back in the same way it came out. Plug in the pc and turn the power on. The bios is now cleared, and you can update it if you like. If this is not what you wanted, or you need more help, reply to me and I can help more.
Hope this helps!
Regards,
Joe
Jan 03, 2011 | Computers & Internet
Does a firmware update for dell optiplex 755 optical drive fix intermittent rebooting issue
dell 755 drivers page
your looking at the wrong firmware
optiplex 755 current bios version: A10 date 6/20/2008
for the CD Drive need to open device manager and check
what brand and model you have for dell used 2 DVD drives
b0a7e29.jpgsony and teac
use the correct firmware on drive, if not the drive will be killed.
if unsure open case and look for name/model on sticker of drive
Jun 23, 2009 | Dell Optiplex 755 Desktop Desktop Computer...
DELL motherboard drivers
if you want a driver for yourdell mother board you can download call the dell support centre they ll send you or else you can download through http://supportapj.dell.com/support/downloads/this is the dells site they ll ask about the model and service tags......
Mar 12, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
394 people viewed this question
David Payne
David Payne
