Question about Cameras
I dropped the camera and the lens zoom thing wont move and it wont turn on
  • 133 Answers
The autofocus motor inside the lens might have been damaged, you should contact your local professional camera store, please don`t try to fix the lens yourself due to its small and fragile parts
Posted on Jan 03, 2011
2 Suggested Answers
  • 94 Answers
SOURCE: i was taking pictures and i dropped my camera and
The lens unit needs to be serviced, possibly marginal repair, so if you look at the lens and it seems to be crooked, you could try GENTLY straightening it , but this may make it WORSE! Do not push it in, try to pull out the side that is already pushed in, if you get what I mean.
Otherwise take it to a repairer.
Posted on Jun 09, 2010
I dropped my pentax k1000 and the lens is stuck. wont focus, wont move at all. do i need to buy a new one and if so, how much/what kind am i looking for?
While turning the camera on, or zooming gently push and pull the lens to get it unstuck. If you have to buy a new one it will cost you $75 here.
Mar 22, 2011 | Cameras
Lens wont move
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Rob
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Have a canon digital ixus i zoom and e18 just flashing up and the lens wont move
Jan 10, 2009 | Canon PowerShot A95 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
Zoom Lens
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Sony Cybershot Camera DSC-S650 won't stay on.
that happen to my camera, exactly same thing. and i figured out when i dropped it the zoom out zoom in lens was bent and stuck part way in camera. My brother was playing around and moved lens and it started to work again. If lens looks a little crooked try moving it or putting it straight. Hope it helps
Nov 08, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Focusing wont work after dropping
probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Oct 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
