I can not receive the bloomberg channel 502, i have the full sports package and all channels work bar this one. Error reads no satellite signal being received, coax looks fine, boxhas been switched off on etc.
  • 50 Answers
See if channel is locked out.
Posted on Jul 09, 2008
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
I only have basic cable with cameron communication and it is not picking up cable channels?
I'm not clear on what you are having trouble with. From looking up the Cameron cable selection list, if you have their 'Full Basic" service , you should be receiving 88 channels. or 93 channels, depending on where you live. And possibly where you live, Cameron has a different package from the ones I mentioned. If you are having trouble with the signal or you are receiving all the channels in your package, you should contact your cable company. Or possibly you are looking for channels that are not included in your package???
May 31, 2014 | Element Electronics Televison & Video
Having problems with signal with the program i want
We need more specific information about the problem you are experiencing on the channel you are trying to view. Are you getting an error message? Is it happening only on the one channel or multiple channels? If it is only happening on one channel, there may be an issue on the channel itself. If it is happening on multiple channels, there may be an issue with the signal off the satellite to your receiver. Please provide more information. I hope this helps.
Ray Calo
DISH Network
Apr 25, 2011 | Televison & Video
I just bought a 2007 Dodge 3500 Laramie and signed up for Sirius radio. I gave them the 12 diget number that came up on the radio screen (channel 184) and when they tried three times to activate it nothing...
I bought a used 2008 Ram 1500 SLT Sport; satellite would stay stuck on channel 184 with no sound, etc.
Solution: Disconnect negative wire from vehicle battery; wait 1-hour then reconnect. This clears satellite radio cache (a.k.a. hard reset).
Turn on satellite radion; Call Sirius support to send activation signal. Wait on phone with tech support; may take them 2 - 3 tries to get signal to take on radio.
Aug 21, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Cant receive my channels i have had xm resend the activation signal 7 times and still wont work
First, turn the radio on and off using the POWER button on the radio - do not just turn off the car or unplug it. Next, make sure your 'sleep timer' isn't set. Next, check your antenna signal level and make sure you're in a location that has at least 2 bars - move until you do.
Now, make sure that you leave the radio ON Channel 1 for at least a half an hour. You should then have your channels back - when you do get all your channels back, turn the radio on and off with the POWER switch, not by unplugging the unit, or pulling it out of the dock or turning off the car. Okay?
Oct 27, 2009 | Delphi XpressRC XM Satellite Radio...
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No Analogue or digital channels!
Hello - I just posted something too. Not sure if its the same problem as yours. If you get a response from elsewhere, please let me know. I'll do the same. In our case we have a blank screen with a bar running across the top of the screen reading 'No signal' on left side and 'C611' on the right side. The 611 might be the last channel we were on !
Mar 07, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
