Require color adjustment Acer AL507 Monitor (add red)
Problem: Full color display was malfunctioning because of a single bent pin in the 'male' connecting socket of the cable from the monitor to the PC systems box.
Fix: Repair the bent pin so that it is able to correctly complete the connection (this is very difficult because the tiny pin must be made totally straight and returned to its absolute exact position), or preferably, replace the cable connector.
Posted on Jul 10, 2008
My web pages are to bright/ white.how do I fix this I would love to be able to see all the images. The background is white which blends with any light colors.
You can try to reset the monitor settings. Press the Menu button on the monitor and select and select Auto image adjust or reset option. This should bring back the colors or you can manually adjust the RGB (Red Green Blue) color bar from the menu.
Hope you find this information helpful.
Thank you for choosing Fixya
Dec 19, 2009 | Acer AL1706AB LCD Monitor
My acer monitor is showing only blues and yellow colors. No reds etc. I tried to adjust it on color resoliution byut didnt work
Try a different video-cable.
Try tightening the connections at each end of the cable.
Try connecting the monitor to a different desktop or laptop,
to see if the colours are correct -- it could be the video-card on your computer.
Oct 29, 2009 | Acer Computers & Internet
Color output to screen lacking red
You have ruled out the graphics chip by plugging an external monitor in, the chips fine.
Now you have to look at the inverter. Sometimes a cable will work itself loose from the inverter, causing the display to go wild and show strange colours where is should be white.
What you have to do is remove the screen bezel (the plastic screen surround) this reveal the screen, look at the bottom of the screen for a thin circuit board with cables coming from it and make sure the cables a plugged in properly.
If you need anymore help or advice please post back.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Red color missing in LCD monitor
if under warranty contact the manufacturer for repairs. otherwise you'd be in the market for a new monitor.
Also check your graphics card. Might be causing the problem rather than your monitor.
Jul 14, 2009 | Acer 22" X223w LCD Monitor
I have no color red on monitor.
Confirm the "no color red" by testing with another PC. If the same condition check if a color adjustment on the monitor is possible... like maybe a default setting. If the monitor still produces a bit of red it might be possible to edit the color adjustments using the advanced graphics adjustments; or a graphics program that your computers' manufacturer has available on your computer.
If nothing works the monitor may need repairs.
Jul 08, 2009 | Computers & Internet
Color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Jun 24, 2009 | Acer X193W LCD Monitor
My acer screen has a red tint to it and is pixilated in lines going up and down if u know what i mean. its not the computer becuase when i turn on the acer screen unplugd from the computer and just the...
There could be a problem with your cable you if you can borrow one and test the cable(thats if the cable isnt wired in to the monitor).
the other thing is a problem with the color mix, im guessing its a CRT monitor, if the picture is correct, there is only one way of fixing that and its to open up the monitor and retune the colors, to do this you would have to do the adjustments live, i am going to say the following.
***Dont concider opening up CRT monitors unless your qualified***
there is a coil in there that will give you a 20.000Volt shock and could kill you.
there cheep to replace, buy a new one.
May 15, 2009 | Acer AC 713 17" CRT Monitor
Text color is not consistent on Acer 191 monitor
THE SITTINGS MAYBE ON THE SIDE OF THE MONITOR HALF WAY DOWN OR HALF WAY UP. MODE OPTION, ACER MAY ALSO REQUIRE A SOFTWARE SETTINGS ALSO JUST NOT SURE WITH ACERS SETUP
RODGANDYSR
Mar 07, 2009 | Acer P191WBD LCD Monitor
Cannot change color on monitor
check the R.G.B voltages at the crt base.if it is ok the crt may be defective.
Apr 04, 2008 | E-Machines eMachines Monitor E15T4
Color
This may be a cable problem, check the connector of your HD15 VGA cable for broken pins (there is usually one pin that is normally not present so don't worry about that one)
Sep 06, 2007 | Acer 17" AL1717 Flat Panel Color LCD...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
