Question about Whirlpool Dryers
My dyer wont get hot - Whirlpool Dryers
  • 472 Answers
Check for proper power in the rear of dryer should have 220 plus voltage across the red and black wires ... if you have power there then your going to have to gain access to the heater assembly and
check the thermostat and heater ...turn power off or unplug and remove access panel and check the thermostat for continuity and then check the heater for continuity with the wires to each removed so you are not reading through anything else...if you do not have continuity on the both of them they are bad...your meter should beep if it has sound or should read 0 if it is good on the ohm setting ....
Posted on Jan 03, 2011
Why wont my matage dryer get hot
If you recently had a power failure or just installed your dryer sometimes its necessary to reset your breaker box. Unplug your dryer and turn off and then back on the breaker switch to your dyer. then re plug in your dryer and see if that works
Apr 27, 2014 | Dryers
My dyer gets hot then it gets e64 then my dyer stops
It could be clogged vent or faulty sensor or thermostat control board Best way is check for clogged vent or any rust or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Kenmore Dryers
Dyer only blows cold air
U may have a blown thermostat or bad heating element.
Nov 14, 2011 | Dryers
Stackable dyer gets too hot in the back and i cannot find a filter
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Samsung DV316LGW Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Thermal Fuse
do u mean that the drum wont go round if so then it could be your mains filter which is faulty this is situated next to your motor either a plastic/metal cyclinder with wording on it will only be about 4in in length
Aug 12, 2007 | Maytag MDE2600 Electric Dryer
Open Questions:
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
