Question about Microsoft Xbox 360 Console
Ive plugged my xbox into a plasma using the rgb cables, but when i turn my system on the screen only shows thin lines of colour, i tried just using the normal video cable, but the same thing happened. whats wrong with my xbox?
  • 839 Answers
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console...
click here to download repair guide
Posted on Jan 03, 2011
When I turn on my xbox the screen shows lines and colours and green/red dots. I can make out what is on the screen but it is fuzzy. The sound is also wrong, on and off and strange when you can hear it. I...
I would try cleaning the connections to the xbox and the TV. Also you could try connecting with a different type of cable (VGA or use the HDMI cable).
If that doesn't clear things up then you could have a hardward problem with your xbox.
Feb 28, 2011 | Microsoft Xbox 360 Console
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
My plasma picture looks green
You are proberbly using RGB leads, wich is red green blue, each colour runs through each cable, have a look at your cables maybe one is loose, or damaged. check on both ends, but the cables MAY NOT be red green and blue, but the terminals that the plug into will be.
Jul 05, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Mar 12, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Samsung, xbox problem
Try to change the hdmi cable...
set your plasma hdmi input...
Good Luck
Dec 10, 2008 | Microsoft Xbox 360 Console
Sony pfm42x1 colour problem
Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
Apr 22, 2008 | Sony PFM-42X1 Plasma TV
Breakout cable usage
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Oct 15, 2007 | Panasonic TH-42PWD5UY 42 in. Television
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
