Question about Belkin Wireless Surf Router (F7D2301)
I accidently put in the wrong isp and password during the setup and now the light wont go green, what do I do?
  • 3 more comments
  • Jeffrey Groves
    Jeffrey Groves Jan 03, 2011
    Did you try running setup again?
  • whouiz90 Jan 03, 2011
    Well I tried to run the setup again but it just isn't appearing. As for the Isp and password, what do I actually put there? I don't have a isp or password it's just at
  • Jeffrey Groves
    Do you have DSL, cable modem, or some other type of Internet service? If you don't have DSL, then you most likely don't need to provide any username or password.
    I have at
    I have at
  • 536 Answers
You will probably need to return the router back to factory defaults in order to run the setup program again on it.
To return the router to factory defaults, press and hold the RESET button on the back on the router for approximately 20 seconds. Once you've done this, unplug the power cable from the modem (not the router) for about 15 minutes. While the modem is off, go back through the setup for the router again.
After you've completed the configuration of the router and waited the 15 minutes for the modem to clear its NVRAM, plug-in the power cord of the modem and let it sync to the network.
If all has gone well, you should then have a working router.
Posted on Jan 03, 2011
  • Jeffrey Groves
    I'm pretty sure that at
  • Jeffrey Groves
    I'm pretty sure that att doesn't require a username and password for their service to work properly.
    Man, fixya needs to fix its support for ampersands!
ISP Username and PAssword
So put in your username and for password, just hit <return>.
Jan 17, 2014 | Computers & Internet
My router light is orange an will not allow me to connect to the Internet. Normally it is green.
i think you need to configure it by putting proper username and password given by our isp internet provider. please check the manual to know how to login to your router and how to configure it if you have username and password provide by your ISP
Oct 15, 2012 | Computers & Internet
No conneck to internet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you have already done this
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 01, 2011 | Computers & Internet
I am unable to connect to the internet. I am asked for a password. where do I find this. The unit is an archos 7 home tablet
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
Mar 14, 2011 | Archos 7 HOME TABLET V2 8 GB Hard Drive
I cant open my internet explorer..
or if this is what you mean
also
hope this helps
don
Feb 19, 2011 | Computers & Internet
HOW CAN I MAKE MY BELKIN ROUTER WIRELESS? THE MODEM LIGHT WONT TURN ON AND THE INTERNET LIGHT EITHER..THE WIRELESS LIGHT BLINKS ORANGE.!
First light only will get green if connection is ready.
  • If your connection is DSL with user name and password you need to setup your connection type PPOE
  • If your connection is Cable just you ned to clone your mac Address to be connect to internet
after this the light of your router will turn on.
Remember power cycle modem and router to be connected.
Any question ask me again and tell me the name of your ISP Internet provider.
please rate me Techbelkin.
Oct 24, 2010 | Belkin (F5D5231-4) Router
Cannot connect to internet. router modem and globe lights blinking amber.
If the modem light is blinking it means that there is activity, so this is normal.
However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type 192.168.2.1 in the address bar.
By default the password should be left empty.
Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
I hope this helps!
Mar 01, 2010 | Belkin (F5D5231-4) Router
CANNOT GET INTERNET TO WORK... SHOWS ALL
If the internet light is red, it means that the modem is not getting the connection from your ISP.
To verify the settings, just access the setup page using a web browser. Type 192.168.1.1 in the address bar.
By default the username is admin and the password is password.
If this doesn't work, try admin for the username and password. If still not working, you will need to reset the modem.
Once on the setup page, go to Configuration.
If you have a PPPOE connection, make sure that the username and password provided by your ISP is correct on the firewall.
If you have DHCP, the modem should be in bridge mode.
I hope this helps! Good luck!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
Dec 29, 2007 | D-Link DI-624M Router (DI624MRE)
Belkin Wireless Surf Router (F7D2301) Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
