I get as check operator service - how to correct
  • 25 Answers
Draw it
Posted on Jan 03, 2011
Konica minolta bizub 164 call service c3451 tell how solve
Warming-up failure
1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Jan 13, 2015 | Konica Minolta Office Equipment & Supplies
I have a 2002 ford ranger fx4, 4x4. auto trans. electronic 4x4 shift mechanism. it is stuck in 4x4 low range. what can i do to diagnose this problem?
run fault codes for starters as they are meant to record any faults for repair. Check all under body wires and connections and ensure that the pins are clean and dirt free. Check ant actuators for correct operation and if vacuum operated check for hoses are operational and serviceable..
Feb 10, 2014 | Cars & Trucks
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
Please define Service A for the Mercedes C280, year 2006. Thanks, David
It is the same for any mercedes. here is a copy from another source on the internet
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
Aug 29, 2010 | Mercedes-Benz C-Class Cars & Trucks
Replaced thermostat, radiator on it, still over heats after about 15 minutes on idle.. Fan never seems to change speeds and idle jumps at higher temperature. Any Ideas?? Thanks!
When engine running, ensure no engine combustion gas bubbles in coolant resevoir (if so, the head gasket is blown).
Check radiator cooling fans are operating ok (as required when car warms up) - if not check
1) fuse,
2) relay operation,
3) heat sensor switch.
Check for collapsing (soft) coolant hose on suction side of waterpump when engine revs above idle.
Check the coolant pressure cap is serviceable & of correct rating,
Ensure cooling system is correctly filled, bleed off any airlocks as necessary,
Check radiator cooling core is not blocked internally or externally.
Jan 17, 2010 | Ford F-150 Cars & Trucks
Hot tub not heating any hotter
It sounds as though the temp. sensor isn't operating correctly. The tstat may have the ability to turn the unit on and off but it may not be sensing the correct temp. I would have a service perfessional come out and check for a short and also that the tstat is operating correctly not just turning on and off. I wouldn't try and bypass due to safety concerns on a hot tub.
Mar 29, 2009 | Home
Service B for Merceds 2005 c230
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Interior
· Function check
Wheels, brakes
Engine compartment
· Brake system
Trunk
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Jan 01, 2009 | 2007 Mercedes-Benz C230 Sedan
F7 Error
This is schematic:
http://www.servicematters.com/docs/wiring/wiring_main.htm
But your correct model # is: GH5184XPS4
F7 Power to magnetron
interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
2. Check the operation of all interlock switches.
3. To check the over-temperature protection for the magnetron, unplug
microwave oven or disconnect power.
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or
blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to
0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected
to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
Dec 06, 2008 | Whirlpool GH5184XPQ Microwave Oven
Air conditioner breaker on plug keeps tripping
The instruction manual says:
If the safety device incorporated in the plug trips and cuts off the power supply, check that the power cable and plug are not damaged. If the power cable is undamaged, to restore operation press the RESET button.   To verify the correct operation of the plug, press the TEST button periodically and make sure the appliance disconnects.  If this is not the case, contact the service center. To restore operation, press the RESET button.
Customer Service: 800-322-3848  US Customer Service: 888-335-6644  Canada
Hope this helps!
Jun 08, 2008 | GE Heating & Cooling
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
