Manual for memorizing a computer keyboard - Computers & Internet
  • 25 Answers
Asdf
Posted on Jan 03, 2011
How to write an email password
Memorably...
Hello Nolwazi Mjwara,
The key to a very excellent password is one that you can remember yet even your closest friend would not divine...
Some folks like to write their passwords down:
I would suggest you write down the RIDDLE for your thoughts
One of the best passwords I ever had was tediously long
and PURE nonsense... like "ASDFGHJKL"...
but if you type with more than two fingers it is not NONSENSE
at all... ( IT IS THE MIDDLE LINE OF YOUR KEYBOARD ).
Helpful?
Carnac the Magnificent
Mar 31, 2017 | Computers & Internet
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Which fuses control the remote deck release and memory seats on a 2002 Toyota Avalon XLS
make sure it is in park with ignition on to adjust seat,
CONDITIONS FOR MEMORIZED POSITION ACTIVATION Ignition key "ON" and shift lever in "P" position All parts of the memorized positions can be activated. However, if the brake pedal is being depressed, the seat position will not change. Key not in ignition switch and within 30 seconds of opening driver's door The memorized position can be activated. If any driving position memory switch is pushed while one of the memorized driving position profiles is being activated, the operation will stop. To reactivate the system, push the desired button ("1" or "2") again. The driving position memory control system cannot be operated while the vehicle is moving. If the vehicle's battery is disconnected, the computer's memory will be erased and the memorized position will have to be set again.
if you wouldve followed
paulmacintyre s answer,you would not have needed to post it again,
Apr 06, 2015 | 2002 Toyota Avalon
How to enter in bios in my wespro n720
Boot the computer.
Just the bottom of the screen when the Wespro logo comes up.
Look for - enter BIOS Setup - and the key after it.
Memorize the logo.
Turn off the computer.
Wait at least 30 second.
Turn it on.
Press the memorized button frequently.
Then it should show up the bios function.
Thanks.
Jan 14, 2015 | Computers & Internet
I'm not familiar about the letters in the keyboard, what will I do to memorize that?
To learn the letters on a keyboard, get an old self-taught typing book. It will guide you through lessons. Good luck!
Jan 20, 2011 | Computers & Internet
Color conversion is off. repairman replaced circut but manual conversion won't memorize. repairman can't find part???
if it does not memorize then the digital board also called the computer is where the problem is at
Jan 31, 2010 | Mitsubishi WS-65807 65" Rear Projection...
How do i make the weather degree sign ? ? ?
In windows, click Start>Programmes>Accessories>System Tools>Character Map. Here you will find every symbol and you can copy this to the clipboard for pasting into any application you require.
Regards
Chris
Nov 06, 2009 | Gateway 2520915 Keyboard
How do I memorize an address on this typewriter I need to memorize a sender and a send to address on a fedex form
If this is a WW30 on the L. side of the keyboard are three keys store, play and delete. To store hold the store key and type an address
01 - 99, release store, type info. press store again. To print it hold print type address release print, delete works the same way.
DickyO
Nov 04, 2009 | IBM Wheelwriter 30 Typewriter
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
Onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Nov 20, 2007 | Onkyo TX-8511 Receiver
Computers & Internet Logo
David Payne
David Payne
