Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
Recently bought a new tag heuer grand carera and accidently got a scratch on the sapphire crystal. Where can it get it replaced and how much it would cost me. Is there any dealer near new hampshire
  • 25 Answers
Sdasad
Posted on Jan 03, 2011
Tag Heuer watch losing time
Make sure the voltage on the new battery is correct. Just because a battery is new does not mean it is good. That is likely the problem.
Apr 21, 2012 | Tag Heuer 2000 Classic WK1320.BB0316 Wrist...
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
My watch stops very often its tag heuer grand carrera calibre 17 rs2 automatic one what do i need to do for continuous running of my watch
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
Jan 21, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    My tag heure chrono's minute and second hands turned black and moisture got in ?
    mcdevito75 here, I hope you have a warrantee on your Tag Heur watch, if so, contact Tag Heur, if not, your on your own, (Sorry) sounds as though it"s lost some of it"s waterproofing ability or the seal around the crystal, usually a crystal sealer. Best Bet look for a small watch repair shop in your area, have them take a look at your watch. The Fog on the crystal is the tempersture change of the air in your watch, no watch is air proof, re-sealing the crystal should help, also, replaceing the rubber seal on the back of the watch.
    Jul 18, 2010 | Tag Heuer Watches
    Dear Sir, The main ticking seconds arm had stopped suddenly.Anything wrong ?? Moreover, I got very slight scartches on the crystal watch cover.How does this happen if the crystal is saphire and anti...
    mcdevito75 here, Hello David, Tag Heur a very fine watch, First I would make sure it is the seconds hand that stopped and not the Chrono. hand, I would also go over any instructions that came with the watch, about the light scratches on the saphire crystal, the crystal is scratch resistant to a point, and can occur almost anyway, rubbing up against something harder than the crystal itself, (certain Stones and materials) even if your in a dusty place scratches can occur on any crystal. Check with your warrantee, you should be covered.
    Jul 13, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
    Can the bezel be repainted and the crystal replaced for a reasonable cost
    mcdevito75 Here, Your watches bezel can be re-plated and the crystal replaced, I have a repair person who does expert work, specially on high end watches, Tag Heur, Rolex, etc. contact me at mcdevito@netzero.com for details.
    Jun 12, 2010 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
    The second hand runs extreamly fast
    Either the watch is faulty, in which case you need to return it to the store which you bought it, Tag Heuer are very good at fixing their watches. If you bought it elsewhere, check that it is genuine, before sending it anywhere, because if not a genuine Tag Heuer, you may not get it back. I'm guessing its a Quartz model, which are difficult to repair but simple and cheap to replace, which is what they will do (Tag/Jewellers) if its an Automatic model, then it will be repaired quite quickly, as very simple to do. Any problems, luxury sauce dot com, contact me via there.
    Apr 23, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
    SCRATCH ON BLUE BEZEL OF WATCH
    If it a scratch on a brushed surface try one of these watch Brush pens
    Here only a couple bucks
    If it is on a polished surface
    try a cape cod cloth here
    both are indispensable watch collectors items.
    Dec 30, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Early tag heuer professional 200m wrist watch
    nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
    Jan 25, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
    136 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
