Question about Mossberg Uag 500590835 Shotgun Red Dot Scope+mountm2
I have a mossberg 500 GA 12 guage with select choke and the bolt stop is not functioning. How can I repair it?
2 Suggested Answers
  • 243 Answers
SOURCE: How do you load a
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Posted on Sep 23, 2010
How to Install a magazine plug on a mossberg 9200
Read the text here
mossberg manual - StevesPages.com stevespages.com/pdf/mossberg_9200.pdf
  1. Cached
  2. Similar
To install the barrel, unscrew the forend cap and remove the forend (Fig. ... MAGAZINE PLUG - You are responsible for complying with all laws regarding magazine ... Model 9200 is designed to fire 12 ga. shells ranging from 2-3/4" target and.
http://stevespages.com/pdf/mossberg_9200.pdf
There are videos on this here
Install magazine plug on mossberg 9200 Google Search
Oct 28, 2016 | Mossberg Optics
How do you remove the muzzle brake
Don't! That barrel's actually a highly desireable item....keep it intact! If you want to go without the muzzle brake, just switch the barrel. Hit Ebay or your next gun show. You can get barrels for the $50-75 all the time of the day.
Jun 10, 2014 | Mossberg 500 Rolling Thunder 12-Ga Pump...
How to remove firing pin spring from mossberg 835 shotgun
Small pin at the back of the bolt. Top edge. Tap it out. As with all pins, just drift it out to the point that you can grab it with smooth pliers and twist it out. Do NOT drive a punch any further into that hole than you need to. Punches widen as they go and you'll deform the hole. Pins are cheap to replace, bolts aren't.
May 06, 2014 | Mossberg 835 Ulti-Mag Mossy Oak Breakup...
Where can i find a magazine loading chamber for a mossberg 835 12 ga. pump? and how much?
I'm sorry but I don't quite know what you mean, sir. Can you explain a bit?
The 835 is a tube mag pump action. You load it by slipping a shell into that open area on the bottom of the gun, slip the shell forward into the tube until it's thumb knuckle into the tube. That gets it past both shell stops.
Apr 09, 2014 | Mossberg Model 835 Ulti-mag Turkey/deer...
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
I have a Mossberg New Haven 600 AT 12 ga. pump. Loaded or unloaded it won't pump unless I push the button underneath. Please help
The firing pin has to drop before it will pump. The button underneath is to safely unload it. If you have it unloaded or use whats called snap caps you pull the trigger and then the action will unlock. Here is a manual and that is covered on page 2. Mossberg 500 pump manual.Hope this helps FixYa up.
Sep 05, 2011 | Mossberg Optics
What is the difference between a Mossberg 500 and a Mossberg 535 max 4.
The 535 is simply a slightly stretched model 500. It can chamber and fire 3.5" shells where the 500 will only handle up to 3" shells. The guns are identical in function and pretty much identical in parts except the stretched bits.
Nov 26, 2010 | Mossberg Sport & Outdoor - Others
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
Sep 17, 2010 | Mossberg Optics
Mossberg Uag 500590835 Shotgun Red Dot Scope+mountm2 Logo
155 people viewed this question
Top Mossberg Optics Experts
obsteiner
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
