I have a new computer (hp), I'm trying to install my lexmark 6100 series to the computer. When I attempt to install, and when say to select the language, I put english, then it say english is not an option, select another language.
    Novelist:
  • 183 Answers
Check the Model Number of your Printer and Got to this Link :-
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Then Enter your Printer Model Number >> Download and Install the Driver for Your Printer according to the Operating System >> I Will Resolve your Issue.
Posted on Jul 09, 2008
I am trying to instal my Lexmark X1270 series to my HP Laptop without success. could you please advise me. Many thanks.
Please visit the Lexmark website to download and install the Lexmark X1270 Printer Driver on your HP laptop. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Aug 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Lexmark X6170 scans but the scanned document is not clear or visible , the words are very light .
You could try to increase the Scan Resolution to improve scan quality using the Lexmark All-In-One Center application on your computer.
  1. Go to Start menu > Programs or All Programs > Lexmark 6100 Series > Lexmark All-In-One Center.
  2. Click Scan menu.
  3. Click See more scan settings.
  4. From the scan resolution dropdown, select a higher resolution value. 300 dpi is the default setting. Note: Increasing the resolution value also increase the scan file size.
  5. Try to scan again.
Jun 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a x6100 all in one printer but the drivers are not compatible for windows 7.although i download the drivers for vista it still doesn't print. thanks
Try to uninstall your printer driver. Follow steps in this article: How to Uninstall Lexmark Printers. Reboot pc when prompted. When the printer turns on, check if your Windows 7 is running on 32-bit or 64-bit System Type. Go to Start menu -> right-click on Computer -> Properties. Take note of the system type.
To download the driver, visit the Lexmark website using the links below: - Lexmark 6100 Series driver for Windows 7 32-bit - Lexmark 6100 Series driver for Windows 7 64-bit
Execute the file and follow the instructions on your computer screen.
Apr 28, 2011 | Lexmark X6150 All-In-One InkJet Printer
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have 2 6100 series HP printers in two different locations. One wireless and other Ethernet connection. I get no problem. Now I installed at a third location an HP 6500 E709n series unit and have all...
That might be because of the clash in the Print drivers.
Installing the Universal print Drivers is suggested.
You can use both the printer with wireless connectivty using such drivers.
First install the printer with Full feature driver.
Then go for Universal drivers.
Make sure that you have the correct IP address and both printers are not clashing in this regard.
Install these inbuilt drivers with separately with different IP address.
To add a new printer, connect your computer to the network and click Start > Printers and Faxes.
Click Add a printer in the Printer Tasks column of the Printers and Faxes window
The Add Printer Wizard will open. Click Next.
Select Local printer attached to this computer, and be sure the box under this selection is not checked.
Select Create a new port and select Standard TCP/IP Port from the Type of port drop-down. Click Next.
The Add Standard TCP/IP Printer Port Wizard will open. Click Next
Enter the IP address of the printer in the IP Address or Print name.
A confirmation screen will appear indicating that the wizard was able to locate the printer. Click Finish
Under Manufacturer , click HP , under Printers , click hp deskjet 990c , and then click Next .
Use default printer name. Set it as default.
Click Finish to complete the setup.
Mar 08, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark 6100 series error message Prop Res DLL not loaded
Download tatest driver sfrom lexmark and use revo to uninstall first
Sep 30, 2009 | Lexmark X6170 All-In-One InkJet Printer
Installation instructions for 6100 to laptop required
Here is the Setup Sheet:
Lexmark 6100 Series Setup
And...the User Guide:
6100 Series User Guide
Here is the link to download drivers if needed:
6100 Support
Click on the Downloads tab. Select the correct one for your Opeating System.
Sep 08, 2009 | HP Pavilion Media Center a1330n - AMD...
I tried to install printer cd HP officejet 6100 series to my new Vista computer but it won't work. What shall I do?
Your printer will not work with the CD that you installed. Here's what you need to do.
First uninstall the software you installed. There should be a shortcut in Start>All Programs>HP
You should also go to Start>Control Panel>Printers and see if there is a printer icon for the 6100. If not, close the control panel. If there is, right click on it and select Delete. Close the control panel.
Reboot the computer.
HP does not support your printer with full feature software, but have stated on their support page that Vista does have a driver for it. There are workarounds for scanning and importing and viewing memory card pics.
Anyway, make sure the USB cable is NOT connected. Power on the printer. Plug the USB cable in. The software should install and give you a "Devices are ready to use" notification.
For additional info, see the 6100 Support Page
Any additional help, please comment back.
Dec 16, 2008 | Office Equipment & Supplies
I need to download the drivers sofweare for my Lexmark X 6100 series but I can find them anyweare > what should I do to download this program
Please visit to the lexmark web site
www.lexmark.com and select Drivers and download tab
Then you can select your printer model and download the drivers and software
if you can't find the same X 6100 try down load The number between 6000 to 6200
Aug 13, 2008 | Lexmark Office Equipment & Supplies
Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your printer...you'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Jan 18, 2008 | HP Pavilion Media Center a1330n - AMD...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
