Question about Samsung Televison & Video
Connection through the Teac set top box gives pictures but no sound. Sound is available only when viewing through the DVD player.
  • desgriffin Jan 04, 2011
    Focused the issue.
  • Samsung Master
  • 6,993 Answers
this means there is nothing wrong with your TV, the problem should be from the Teac set top box. To further confirm, if you have another TV, connect it to the Teac set top box and if there is still no sound, then it is obvious that it has a problem.
But first, check the audio wire and make sure its not defective. Also, check to make sure mute is not turned on, on the Teac set top box and make sure the volume on the remote control is raised to the highest. Check the back of the Teac set top box, make sure you connect the audio cord/wire to the right spot (Audio out).
Is non of the above is the cause of the problem, then it means the sound card/IC of the Teac set top box is defective, that's why it won't bring out sound.
This also means you will have to change the whole board for the Teac set top box, because both the video, audio and other components and on the same board. You might also end up taking it to a repair man because it take a professional to fix the problem.
But I hope this problem is a connection or settings problem.
Wishing you all the best.
Posted on Jan 03, 2011
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
My LG DVB-T HDD/DVD Recorder will not play or record sound via TV Channels!
If the TV source is separate from the recorder, there has to be a physical connection between the two. From your description it seems there is a video connection, but what about audio?
Dec 03, 2013 | Televison & Video
Sound from anything but cable?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
Jul 11, 2013 | Coby TVDVD2050 20 in. TV/DVD Combo
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Feb 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I dont have manual and i am trying to find and set channels on my teac sdb450 set top box
43D8UXA Toshiba TV - DVD playing with sound. No picture on tv, Playing normal tv but not DVD.
worked 2 days ago. How do I adjust the tv to get picture?
Jan 24, 2009 | Televison & Video
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Televison & Video Logo
195 people viewed this question
Jerry Greenberg
Jerry Greenberg
