Question about B&W DM603 S2 Speaker
What is the price of bw speaker single tweeter model:DM603S2 in singapore?thanks.
Need 2 tweeters for theses speakers
Bowers and Wilkins? A great product. The MD is a friend of mine and I have done the factory tour! Great product and great support service. I have a number of BW items :>)
Parts Pricing Availability
Aug 23, 2015 | Audio Players & Recorders
A replacement tweeter for Yamaha S215V speaker
I generally get replacements from Simply Speakers. Their site is-Replacement by Simply... Genuine Eminence Parts New
You can also just replace the diaphragm. The procedure is on YouTube here-
Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply... Genuine Eminence Parts New
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box.
Feb 17, 2015 | Yamaha S215V Main / Stereo Speaker
Where can I find a tweeter for Yamaha S215V speaker? Thanks
I generally get replacements from Simply Speakers. Their site is linked below.
You can also just replace the diaphragm. The procedure is on YouTube linked below.
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box. Genuine Eminence Parts New Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply...
Left tweeter is not working
The tweeter could have failed. Failure of a single speaker does happen occasionally
May 10, 2013 | Altec Lansing MX6021
Peavey sp2 pa speakers quit working
Ok,
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
Tannoy v1 reduced brightness from one tweeter, diagnose? replace? honestly unsure if broken tweeter is the duller one or the brighter one, help?
I assume you have more than one of these speakers. If so simply remove the tweeters from the two speakers and swap them around. If the other speaker acts up then, you know the tweeter is faulty. However if it stays on the same speaker it's the crossover that's the problem.
Jun 11, 2017 | Audio Players & Recorders
Tweeter went out
This websight has a good selection of speakers at good prices. www.mcmelectronic.com Give it a look and let me know if it was helpful and if I can be of anymore help.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Tannoy Fusion 4 Main / Stereo Speaker
Jbl e80 no sound coming from tweeter
Sound like the tweeter is blown, take to local jbl agent for service.
Sep 16, 2009 | JBL Northridge E80 (Single) Main / Stereo...
I need to know who is better for my cherokee sport 1999 ..!!!
Hello leonardoe,
The MB Quart's are component speakers and the PPI's are coaxials. In an "apples to oranges" comparison, the MB Quarts win. Most component systems in the same price range as a coaxial will have better sound imaging simply because you can mount the tweeters up high for better high frequency dispersion. Some also allow you to make adjustments to the crossover, which is built-in and fixed on the coaxial.
But component systems are more difficult to install. If your vehicle doesn't already have the wiring for separate tweeters, you have to install it. Likewise, the mounting of separate tweeters adds to the installation complexity.
Hope this helps.
Jul 15, 2009 | PPI PC650C Coaxial Car Speaker
Power and ground
The wire with the stripe is normally the negative (no the same as a ground when it comes to speakers), and the solid wire is the positive. Wiring a single speaker backwards won't blow it, it will only cause it to be out of phase. In some cases speakers are wired out of phase or creatively intentionally to create a desired effect or impediance.
Hope this helps.
Mar 29, 2008 | MA Audio MA589 Car Tweeter
B&W DM603 S2 Speaker Logo
60 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
