Question about Epson RX590 All-In-One InkJet Printer
Service Required Parts inside your printer are near the end of their service life. See your printer documentation.
    President:
  • Epson Master
  • 2,022 Answers
Unplug the power and USB cables from the printer.
  1. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  2. Unscrew the screw at the back of the printer.
  3. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  4. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  5. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  6. It is recommended that once you have done this, you let them dry.
  7. Now return the pads back into the printer.
  8. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  9. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  10. Download and install the SSC Service Utility for Epson Stylus Printers.
  11. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  12. If it asks if you replaced with the pads; say "YES". Then close the window.
  13. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  14. A menu will appear, from here you can click on "Protection counter" (its a red cross), then "reset protection counter".
  15. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Jan 03, 2011
Epson 1390 service required
You can get product cover for service only (after warranty)
has ended, check with outlet stores.
Nov 14, 2013 | Office Equipment & Supplies
We're getting this Service Required message - Parts inside your printer are near the end of their service life. See your printer documentation. What part are we needing to replace?
the parts most likely to be replaced with such a message are the waste ink pads. (sponge pads that collect the ink that is used for print head cleanings). these pads are difficult to reach inside the printer (full dissassembly is necessary) and doing so is a VERY dirty job. i suggest contacting a repair center near you.
Sep 11, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are at the end of their service life. See your printer documentation.
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
PART INSIDE YOUR PRINTER EPSON STAYLUS PHOTO R230 ARE AT THE END OF THEIR SERVICE LIFE SEE YOU PRINTER DOCUMENTATION
Mar 09, 2009 | Epson Stylus Photo R200 InkJet Printer
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson RX590 All-In-One InkJet Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
