Question about Cameras
Corrupted memory card: how do i recover all my files in my Kingston MiniSD card?
    Genius:
  • 1,177 Answers
First take the memory card out of the camera. Pictures that have been deleted are probably still there, but will be overwritten if you take any more pictures on top of them. If the corruption is extreme, you may not be able to get back all of the pictures anyway, but often it is only the filing system or directory that has become messed up, and the files themselves can be found with an undelete program.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the files. Undelete programs are available for free download from the internet, try the one at THIS LINK As the pics have not been merely deleted, you will want to use the surface scan function (normally used to recover pics from a card that has been formatted).
If the pictures are very important to you, you might want to seek help from an experienced person.
Posted on Jan 03, 2011
Driver download
SOLUTION 1 - Unlock the memory card. There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked. NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the microSD/miniSD adapter. The SD adapters will also have a lock switch. SOLUTION 2 - Toggle the lock switch. If the lock switch is loose and moves easily It is likely the switch is sliding to the locked position as the card is placed in your host device. In this case the card will need to be replaced. SOLUTION 3 - Try to Format the card using Disk Manager (For all memory cards) The data on the memory card may be corrupted. Format the card under Disk Management and then try to transfer files to the device once more.
May 01, 2013 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sd memory card says its full but its really not
This may be the formatting type you have on the card. Is it NTFS (better) or FAT32 (not as efficient)?
Apr 15, 2012 | Kingston 2GB Micro, MicroSD, MiniSD, SD...
I HAVE A ANDROID HUAWEI TOUCH CELL PHONE, I HAD A 1G MICRO SD CARD INSERTED AND IT WAS ALWAYS WORKING FINE UNTIL TODAY, WHEN I ATTEMPTED TO VIEW IT CONTENTS FROM MY PC. I REMOVED IT FROM THE CELL PHONE AND...
you can try some mobile phone data recovery software. You can see
http://www.youtube.com/watch?v=jOSOGjaVd80
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Sep 02, 2011 | Kingston Secure Digital MicroSD /...
How can i fix my memory card corrupted? tnx
The CDR (8cm) is not a memory card it is a compact Disk Recordable. It can be recorded to and appended to but not erased like a CDR/w. If it is corrupted it is most like due to the age of the disk and the breakdown of the recordable compound which makes up the disk, information generally cannot be recovered if this has happened.
If the disks has scratches on the other hand you can get a disk repair system like Disk Doctor and repair scratched disks.
If you are in fact referring to a memory module which "Kingston" does in fact manufacture, memory modules cannot be repaired by the normal Joe and requires replacement if it has become damaged/corrupted.
Hopes this helps
Mar 15, 2011 | Kingston CDR-8CM Other
Can corrupt sandisk card be restored
you can try this memory card recovery software named asoftech data recovery software. You can see
http://www.asoftech.com/adr/
Sep 14, 2010 | Navigator Evesham Nav-Cam 7000 GPS...
N70 Cellular Phone: how to recover corrupted memory card...
First of all, you should stop saving any new files to your Nokia N70 ( or memory card) or taking new pictures.
Then find some photo recovery software from the following websites, which are able to recover deleted or formatted photos and movies from cell phone, digital camera, memory card and SD card etc. It also recovers photos from corrupted memory card.
Digital Photo Recovery for Windows
Digital Photo Recovery for Mac OS X
Here are the steps:
Step 1: Download and install the Digital Photo Recovery Software.
Step 2: Connect your corrupted memory card to your PC or Mac.
Step 3: Scan the source drive where your lost pictures located.
Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
Best regards!
May 16, 2010 | Nokia N70 Cellular Phone
Im simply seeking the cheapest and easiest way to obtain the code I need for my samsung ce0168 mobile phone to access my deleted files
if you saved your files on your sd card this is how you get them back
Tips & Warnings
  • Don't take any new photos or add new music until you've tried recovering the files. With every new file you add to the memory card, the chances of recovering deleted data decreases because it is being replaced by the new files. That's why you should attempt data recovery as soon as possible.
  1. Download Pandora File Recovery (see Resources for link). Save it to your desktop.
  2. Step 2 Install Pandora by double-clicking the install file on your Desktop. Click "Next" to start the install process and "Finish" once it has completed.
  3. Step 3 Remove your SD memory card2.gif from your phone. If you are unsure where it is located or how to remove it safely, consult your cell phone's manual.
  4. Step 4 Insert the SD memory card into your computer's SD memory reader slot.
  5. Step 5 Open Pandora by going to "Start > Programs > Pandora Data Recovery2.gif".
  6. Step 6 Click the "Browse" tab within Pandora. Scroll down through the list and select the computer drive with your SD memory card.
  7. Step 7 Click the "+" icon to access folders within your SD memory card. When you find something you want to recover, right-click the file and click "recover" to begin the recovery process.
  8. Step 8 Click "OK" to confirm you want to recover data. Data will now be recovered from your cell phone. Then exit Pandora by clicking the red "X" icon at the top right of the screen.
THE FREE PROGRAM
http://download.cnet.com/Pandora-Recovery/3000-2094_4-10694796.html
you may also need a minisd adapter to put the minisd card in so you cn put it into your comptuer.
their is no specific codes you can put into yoru cell phone to get your data back.. Only 3rd party software. you may also be able to take it back to the cell phone store. Espically, if its an actual one, and not a 2nd party store. (examples.. a mall booth, walmart, kmart, ect.) An actual service provider store. They might be able to recover for you also.. They also will have the sms (sim) card readers.. They can put your sim card in.. If you want info recovered on your sim card. they gotta do it for u if they can.
Oct 20, 2009 | Cell Phones
How to recover datas from corrupted N72 memory card
You may try this mobile phone recovery software named asoftech data recovery which helped me before. You can download trial for free
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Apr 24, 2009 | Nokia N72 Cellular Phone
Kingston flash memory card miniSD 512MB password unlock
if you did not change or put any password, just try to use the generic password as 000000 or 123456, if you can connect your phone to the pc, try to download all your files from the memory card to the pc and reformat your mem card
Oct 20, 2008 | Computers & Internet
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
