Question about Seagate (ST380011A) 80 GB IDE Hard Drive
3 partitions missing on a 250gb SATA hard disk
Hi!
I have a 250gb SATA harddisk.which is working as a slave drive on my computer (primary is a IDE harddisk) everything was fine until today morning when i switched on the system to find that , out of the 4 partitions on the 250gb harddisk , 3 were missing.
under diskmanagement it says,
disk 1-
dynamic,
232.88 gb
online
and shows G: on the right hand side as a partition with 232.88gb
but under my computer it says, G: total space 19.5GB, available 17.4GB.
Also H: I: and J: are missing!
Any help will be appreciated.
-regards,
Pradeep
  • Anonymous Mar 27, 2014
    250 gb sata 5400.4 only displaying 116gb available after being formatted
    Champion:
  • 208 Answers
I think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Posted on Aug 01, 2008
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Only 125G is showing
A disk-drive can be "partitioned".
It's possible that your disk-drive has two partitions:
* a "primary" partition of 125G,
* an "extended" partition of the "other" 125G,
with a "logical" drive allocated within the extended partition.
Inside your laptop, you would have seen 'C:' as the "primary", and 'D:' as the "logical" partition, and 'E:' as your CD/DVD drive.
So, if UBUNTU is only looking at the "primary" partition, it will report 125GB.
Connect the drive as a "slave" to some desktop computer, and check for having multiple partitions, and do your backup from that system.
Jun 17, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
I did delete partition of drive 0 Acer 7720G
Go to Control Panel > Administrative Tools > Computer Management > Storage > Disk Management (Local). Choose Drive 0 and right-click on it. Choose "Mark Partition As Active".
That should fix it. You may have to format the drive after all.
Dec 31, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Can I use this Hard Drive as a slave on my PC ?.
Hey,
Ofcourse you can, look at the top of the hard drive to find the jumper settings lable, change the jumper so the drive is slave.
Then connect it to your computer with a ide cable, if you have another hard drive on the same cable the other hard drive needs to be set as master, and be preferably on the end of the cable and slave on the center of the cable.
Then check your bios / cmos / cmos setup / computer setup, right when you turn on the computer to see if the hard drive is detected and properly installed.
heres a video on how to use bios
http://www.wonderhowto.com/how-to/video/how-to-use-bios-69712/
if everything is okay it should show up in windows, if it doesn' then right click on my computer, select manage, then on left side select disk management, you may have to initialize and or partition the disk first before it shows up on my computer.
Thanks and good luck.
Ekse
May 05, 2009 | Computers & Internet
My computer didnt recognize my hard disk
Looks like the controller on the Hard disk has malfunctioned. I am afraid, that the Hard disk has to be sent to an expert nearby for Data Recovery. They would have tools which could be used for getting your data intact. But again it all depends on the level of damage to the Hard disk.You may get all / some of your data ot you may get none. Please consult your hardware vendor for this
Apr 13, 2009 | Western Digital Caviar 40 GB Hard Drive
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
166 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
