Question about Intel DG31PR Motherboard
3 bip sound - Intel DG31PR Motherboard
    President:
  • 2,017 Answers
If you have any add on display graphic card on your system remove that and try to switch on onboard display. This is motherboard problem.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Jan 03, 2011
No dial tone
Different country has different type of tone (in USA sound is constant frequency, some country has bip-bip sound...). Sometimes detection of this sound tell message like this. You always have some option for disable this option. Just try to unmark this options (look on some properties tab).
Aug 24, 2011 | Computers & Internet
While starting its get bip sound upto window will start
Bip sound contiously might caused by 1.Fan stops working 2.Sticky key on keyboard
Try cleaned those two part, specially the heatsink ( something might blocked the fan )
akee_akee@live.com
Aug 17, 2011 | Acer Aspire 5738Z-423G32Mn Notebook
USE A NIKON F-801S GET THE MESSAGE ERROR fEE 8 and a bip bip bip sound the film is new/ battery full / use a lense Tamron af
Turn the aperture ring on the lens to its smallest opening (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera, the same was as on a lens without an aperture ring.,
Mar 21, 2011 | Cameras
I put a new batter in and I get a bipping sound
it means a the value is wrong , 2. it not in the central position.
Regards
GeWiz.
Aug 10, 2009 | Pride New Mobility Celebrity 3 wheel...
Computer didn't start
The bip-bip sound means that a necessary input/output device is missing or not working. Go to dell.com/support enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Apr 29, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
What does the bip sounds sounds mean on my pc
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
May 08, 2008 | Tiny Computers B1996 19" CRT Monitor
Intel DG31PR Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
