Question about Cell Phones
My time and date settings is not working in my mobile samsung gt 5560. The default date is automatically saved ie., 01.01.1900 and the time as 5:30 am if i select gmt for india.
  • 2,133 Answers
Setting> Time and Date> change time and date by pressing numbers as you alike and then press save.
Posted on Jan 03, 2011
Can't find how to change the date or time
System
Setting the date and time
To set the date and time, tap
APPS
Settings
Date & time
Tip
: If you travel frequently or live in
an area that uses daylight saving
time, and have mobile network access, activate
Automatic date & time
from this menu. Your tablet will set the date and time based on information
it receives from the network
Mar 11, 2014 | Acer Iconia A1-810
Connection preferences
If you are connected to the internet using proxy account, you have to add your server name, port number, id, password etc.. But if you just directly connected to the Isp using a username and password, just select "connect directly to the internet" otherwise you'll have trouble signing in to your account.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Yahoo Messenger
How do i set the time on it
Settings -> Phone Setup -> Time and Date -> Set time/Date. Check that your home city is correct first Settings -> Phone Setup -> Time and Date -> Set home city ... otherwise you'll get odd daylight savings changes :)
Jun 05, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I try to connect to yahoo messenger and I get a message that says there might be a problem with your internet connection, i run the trouble shooter in this message and it says possible problem with http...
Right click on your internet connection logo (2 blue monitor screens) in the System Tray and select "Diagnose and Repair"
No Problem? proceed.
Internet Explorer is used to sign into Yahoo Messenger. If you have another browser set as default IE will still sit as a link between your browser and Yahoo Messenger. For this reason most troubleshooting is concentrated on Internet Explorer.
Try each of these in turn, and try to sign in after each of them - if successful (or not) please feed back information to help others.
1) I would recommend installing the latest version of IE and update any support software (Flashplayer, Java, Shockwaveplayer) for IE by using an update checker
http://www.filehippo.com/updatechecker/
2) Start with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
3) On the sign in page click 'Messenger' > Connection Preference
Toggle between 'Connect direct to the internet' and 'Proxy setting' make sure the information is correct in the lower 2 boxes. I am currently in the Asia Pacific region and I have to toggle between these settings a few times a week to maintain my connection
4) Check these settings in IE (even if you have another browser set as default)
a) Tools > Internet options > Connections > Lan settings > check 'Automatically detect settings - uncheck other options.
b) Tools > work offline - make sure this is NOT checked and has a red X through it
5) Disable your firewall and do a trial sign in
6) Control Panel > Internet Options > Connections > LAN Settings-uncheck Proxy server and check automatically detect setting
7) Control Panel > Internet Options > Connections > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
8)If you are unable to sign into this secure page (https)
https://login.yahoo.com/config/login?.src=fptx._intl=uk
copy the yahoo https address above and paste it in here:-
IE > tools > internet options > LAN settings - check automatically detect settings > Advanced - paste in 'Secure' window > OK
9) Run ccleaner again
Feb 10, 2010 | Yahoo Messenger
Cannot login
try the forgot password, even if you know the password, it will help you with all the details, and you might be able to reset the password.
Feb 04, 2010 | Yahoo Messenger
Trobleshooting when i sign in yahoo messenger???
the sign in did not connect in  time basicly the internet connection was not active that's way you get a window that say troubleshooting or cancel.
Feb 01, 2010 | Yahoo Messenger
Everytime i type my password and user name, the smiley face will begin to go yellow then turn to gray again. then a box will pop up saying that "messenger encountered a connection problem. please check the...
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
5. Control Panel > Internet Options > Connections (tab) > Lan Settings (button) then uncheck the Proxy server checkbox and check automatically detect setting
6. Control Panel > Internet Options > Connections (tab) > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
Please rate my response!! Thanks, SF
Jan 28, 2010 | Yahoo Messenger
We can't sign you in to yahoo! Messenger.There might be a problem with your Internet connection. Make sure your computer is connected to the internet. Click Troubleshoot to begin a series of tests to try...
1) Yahoo are concentrating their efforts to resolving sign-in issues with Messenger 10. You may have to upgrade to this version if you cannot resolve your problems and make use of the troubleshooting software - even if you want to retro install an older version later.
2) users who opt for a default browser other than IE may be neglecting to keep IE up to date unaware that IE plays a crucial part in the running of Yahoo Messenger. I use Firefox as my default but note the amount of cleaning in IE when I run ccleaner.
3) Start your trouble shooting with a clean browser
4) It will be worth making IE your default browser while you troubleshoot
5) Download the latest IE from Microsoft
http://www.filehippo.com/download_internet_explorer/
6) Ensure 'work offline' is unchecked :- > Tools - uncheck Work Offline.
7) Update your support software for IE using the links on this page
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
8) If your log-in fails, interrogate the troubleshooting log for 'failed items'
Two Yahoo servers are used for initial log-ins
The log-in server checks your username and password are correct
If this has 'failed' check your IE can access a secure website by signing in here
No luck? check IE settings >Tools > Internet options > Connection tab > LAN > 'Use a proxy server for your LAN' > Advanced - Under 'Proxy address to use' check the info in 'Secure' and 'Port' are correct > OK for each window.
The connection server helps find the right location to synchronise with other servers- if this shows 'failed' change your YM settings to connect via a proxy.This can be done from the menu on the sign in page > Messenger > Preferences > Connection -adjust settings > Apply > OK
If all else fails - try dis-abling your firewall and do a test sign in.
Jan 09, 2010 | Yahoo Messenger
To set memory card as default storage. Model S5233 Samsung
Hello ... you can change the settings to save teh files directly to the memory card...
Go to Settings>> memory settings >> default memory>> select bluetooth>> set the memory as external memory...
May 26, 2009 | Samsung Cell Phones
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
