Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My Macbook won't start up. I was using it yesterday when suddenly it just shut down. Sometimes it does that when the power cord is not connected but this time, the cord was connected. I have tried all of the re-start procedures I've found online: Taking the battery out & unplugging it then turning it on then putting the battery back in & plugging it it and turning it on. Ctrl-Command power button turn on Optin-Command-P-R turn on For all of these the gray screen came up with the Apple and spinning disc, but before too long, in either shuts down or the screen goes black. At one point, I could faintly see my desktop but that didn't last long either. I have also tried putting in the Mac OSX disc and turning it on. This brought up a menu that asked me how I wanted to install my hard drive. As I went to make a choice, it turned off again. Is there anything else to do? Is it worth even taking to get fixed or is it completely ruined now?
    Problem Solver:
  • 12 Answers
Hmm sounds like u got ramed or logic explosion if its still under warenty take it to an apple store and say yo give me a new mac >:( and there like is it under warnty and u be like yeh (dont say u open itttttttttttttttttt) because it might of voided it say you took it to a apple person and they didnt really know if they ask
Posted on Jan 12, 2011
How do i repair an ASUS z53E motherboard?
Have you confirmed that it is indeed the laptop? (IE attached another power supply of same voltage/amperage) Sometime, cords can become frayed inside the laptop power supply cable and not show any outward signs. This wear and tear leads to unstable power and the laptop senses this and will not boot.
If you have, have the laptop checked at a local repair shop to see if it is a loose connection on the motherboard. Ports coming loose from the motherboard because of wear and tear is very common.
Apr 07, 2015 | ASUS Computers & Internet
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Macbook pro won't start/charge
It appears as if your power supply is dead. The power supply is inline with your power cord and has a light on it, if I am correct. Since the green light was dim, then went out all together on your power supply, that would indicate that it would not take a charge any longer, and the dim light, down to none, was the rest of your battery draining. Assuming you tried multiple power outlets, my suggestion would to borrow a power source from a friend and check it, or go to best buy/Apple store and have them use one of theirs to see if it comes on.
Sep 25, 2012 | Apple MacBook Pro Laptop Computer with...
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
It shows message as "turn on camera" while try to
Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
b) Try resetting your SMC:
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
Dec 20, 2010 | Computers & Internet
Hej. Yesterday, suddenly my Macbook air´s keyboard and the touchpad started not to react. I didn´t do anything, just let my laptop on the tabel for 5 min. and when I came back, it wasn´t...
when your keyboard and touchpad are not working, try to connect an usb mouse and keyboard to the laptop, just to be sure the system is responding.
if the usb devices work, you can be pretty sure there is an hardware problem. if the usb devices don't work too, maybe the system got stuck, and the best thing to do is a system reset
How to Restore MacBook Air to Factory Settings
if the usb devices work, give a try to the apple hardware test to see if it detects anything.
Using Apple Hardware Test
i had a similar problem a few years ago.. if it's an hardware problem you will need to change all the top case
MacBook Air 13 Top Case eBay
Jul 30, 2017 | Apple MacBook Air
Before my computer use to get really hot and then my computer use to shut down. I think there is a problem with the fan. Today when I switched it on the apple logo will come with the sound when it starts....
there have been problems with MacBooks suddenly shutting down since the first Intel based MacBooks were made. It is called RSS. (Rapid Shut Down Syndrome). The cause of which I have learned in the following excerpt.
Since isolating the heatsink as the cause of the MacBook’s Rapid Sudden Shutdown (RSS), readers have isolated the specific part of the heatsink that is causing the problem, is actually the CPU thermometer itself. Essentially, the heatsink can expand during use, and comes into contact with the lead from the thermometer’s sensor cable. A short circuit results, and the SMC pulls the plug. Once the system cools down, the heatsink resides and the contact is broken. This also explains why sometimes you cannot immediately power the MacBook back on. The heatsink is still in contact with the metal lead.
Apple’s solution to this is to realign the location of the thermometer and cabling on the heatsink so that it does not short circuit. That is why the new heatsink is necessary. In the view of this writer, it warrants a public recall. Any user can produce easily the scenario that causes the MacBook to crash, even with pre-installed applications such as iLife.
My 2 cents,
Thanks
Fame !
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
85 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
