Question about GE Dishwashers
Just had a reveser osmosis system installed, #GXRM10G. Five blue lights appeared when the battery was installed. Water ran into it for 6 or 7 hours; however, a day later it continues to run water with the constant sound of water going down the drain. Is something wrong? Shouldn't it turn off when filled?
  • 190 Answers
Dear customer,
check the following and see whether your problem is solved
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
  • check air gap.
hope u find this to be useful. thank you for using fixya.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
Kinetico reverse osmosis water flowing very slow
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Jan 21, 2013 | Refrigerators
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
I own the Wher25 Reverse Osmosis system. I
There is a blue cap on the body of the white pressurized water tank. Twisting off the blue cap, you will see a air nozzle - similar as those on the tire. You need to pressurized the tank to 60 PSI. I spend hours to figure out this solution on my own system.
Mar 14, 2010 | Home
Problems with reverse osmosis water treatment system
http://www.ag.ndsu.edu/h2oqual/watsys/ae1047w.htm Treatment systems for household water supplies gives a great description for reverse osmosis systems. I am not familiar with the Maruyama system since I live in the states. After reading the above article you might want to test your water. Your system may be operating properly? To me it soulds like you have a water softner and flushed the salt out, and now you have the proper pellets? If your water is not very hard you shouldn't use too much salt. Building supply stores sell cheap water test kits. Try that, and if your water tests ok, and doesn't smell, and lathers up with soap sounds like everthing is working ok. Hope I helped
Apr 24, 2009 | Mountain Plumbing AG600S Air Gap for...
Kenmore side by side dirty water
the problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Dishwashers Logo
164 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
