Question about Lexmark X5650 All-in-One InkJet Printer
My lexmark x5650 ran out of ink and i replaced the cartridges and it keeps saying to replace them. they are new please help.
I have had same problem with same model. As ink is used there are tiny internal electronic fuses which 'blow' as ink is used and cannot be reset. Sorry you need to buy original cartridge.
ianparronline.wordpress.com
Posted on Jan 10, 2011
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: SAys replace ink cartridges.. did that but still
    The problem sometimes is that when you unpack the cartridges a little bit of residue of the packaging stays in the printhead of the cartridges. Here is a link that shows you how to clean the nozzles. http://www.bit.ly/aBjxGa
    Posted on Feb 13, 2010
    I just bought ink cartridge and says ink low on my lexmark x5650 so i just bought ink cartridges for my hp 4140 and it wont work, is this a cproblem with my computer and not my printers? 2 printers do
    As far as the Lexmark printer is concerned, try the steps below:
    The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
    1. Make sure the printer is on.
    2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
    3. Remove both cartridges from the carrier.
    4. Close the printer cover.
    5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
    6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
    7. If no error appears, reinsert the other cartridge. Close the printer cover.
    8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
    Feb 12, 2012 | Lexmark X5650 AllInOne InkJet Printer
    I dont know how to change the ink cartridge on my lexmark?
    For more detailed instructions on how to change/replace the ink cartridges in your Lexmark printer, please refer to the Lexmark X5650 User's Guide. Turn to page 111 - Maintaining Print Cartridges.
    I hope this information has been helpful.
    Nov 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
    I can't find the door? to open to put in a new ink cartridge
    For the X5650, with the printer on, lift the scanner unit (lift from near the center - just above the keypad). There are supports on each side that will hold the scanner unit. The cartridge carrier should move into the replacement position. Then press down on the levers at the front of the cartridge carrier to have the cartridge lids open.
    For pictures, see the manual: http://www.lexmark.com/publications/pdfs/2007/5600-6600/v7677571_en.pdf . Additional documentation is available here: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X5650&focusedTab=PUBLICATIONS#1 .
    I hope this helps.
    May 31, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
    It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
    Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
    Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
    Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
    Aug 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
    I have a new Lexmark X5650. for the first time I changed the black ink cartridge with an original 36 as indicated, and yet it tells me I am out of ink! Help! Thank you
    Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source and leave it unplug for now. Then, wipe the nozzles of the cartridge using a damp paper towel. Plug the printer back to its power source. When the printer's ready, re-insert the cartridges. Close the cover. The printer will print an alignment page. Just let it print the page without cancelling it. If that doesn't resolve the problem, try pressing the Settings button on the printer control panel. Go to Maintenance, then hit ok. Select Clean cartridges, then hit ok. That will force inks out of the cartridges and also cleans the nozzles. You can check ink levels by pressing Settings on the printer control panel. Then go to Maintenance, select Check Ink Levels. If ink level is still not recognized, have the ink cartridge replaced. You probably got a defective one.
    Apr 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
    Feb 04, 2010 | Lexmark X4650 InkJet Printer
    Hi i have a lexmark x5650 printer, i have just refilled the cartriges and it wont recognise them keeps telling me to replace them, any ideas any one ? neil.
    I had same problem. I unplugged the unit, took a pink pencil lead and lightly cleaned the contacts, put the ink back in the plugged unit back in and it worked.
    May 01, 2009 | Lexmark Office Equipment & Supplies
    Lexmark X5650 All-in-One InkJet Printer Logo
    216 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
