Question about Nokia 3230 Cellular Phone
I HAVE NOKIA 3230.ITS MEMORY CARD IS LOCKED N I DONT HAVE PASSWORD. WHT WILL BE THE SOLUTION FOR THIS ISSUE
  • 2,133 Answers
Tounlock cell phone Passwords:Instructions
Enter the last four digits of your phone number on yourcell phone PIN screen. Enter 9999, and if that doesn't work try 1111, and ifthat doesn't work try other 4 digit numbers you may have entered. Shut off your cell phone, take off the back of your phoneand pull out the battery. Record the IMEI number which is under the battery.Re-insert the battery and power on the phone. Enter the last 4 digits of theIMEI number on the PIN entry screen. Callyour service provider and request the unlock PIN. You will have to prove youare a customer by stating your cell phone number, addressand social security number. Turn off your phone. Hold thekeys "3," "*" and "Call" and switch the phone on.Hold the three buttons down until the word "Formatting..." appears onthe screen. This should reset the phone lock code. Read more: How to Unlock a Cell Phone Password ' eHow.comhttp://www.ehow.com/how_4810931_unlock-cell-phone-password.html#ixzz19YU6TIa2
Posted on Jan 03, 2011
After formating nokia 3230 memory card is locked autometically
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 13, 2010 | Nokia 3230
Hi Sir=)
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 21, 2010 | Nokia 3230
How to remove microsd memorycard password
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
Feb 25, 2010 | Nokia 3230 Cellular Phone
Sir i gave password for my nokia 3230 mmc memory card to protect against illegal use. but unfortunately i dont remember the password,so I am unable to use my memory card. please help me unlock it
Install and launch MMCPWD application. It will display some special characters including your password.
Option 2:
Locate mmcstore file. Install and launch System Explorer or FExplorer application. Go to c:\system\ and open (using unicode/hex editor) the mmcstore file. it will display your password. NOTE: you can also copy the mmcstore file to any folder of your phone memory, rename it to mmcstore.txt and open it without using any unicode/hex editor).
Option 3:
1. Open up fe explorer thingy.
2. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
3. Copy it to C:\nokia\others
4. Highlight it
5. Click options
6. FILE>RENAME
7. IT should turn blue: right click then write ".txt" (should look like "MMCSTORE.txt"
8. Try to open it, (that should be your password, if nothing happens then go to 9.)
9. Connect phone to pc
10. Open the file from C:\NOKIA\OTHERS\MMCSTORE
11. Copy the file to your desktop
12. Open with Windows notepad/ microsoft word
13. That should be your password
May 06, 2009 | Nokia 3230
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
My nokia 3230 memory card is locked after i formatted it by the secret nokia method pressing the power key along with the dial key and 3 and star
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
please rate me.
Nov 15, 2008 | Nokia 3230 Cellular Phone
I want break my memory card password
Nov 08, 2008 | Nokia 3230 Cellular Phone
there is no way to break if the password is forgotten for the memory card, but u can attach the card to the memory card reader to the computer and format the card and u can use it
Forgot of memory card password
check help in the mobile but as far as i know u need to take it to the nokia shop to get it done
Aug 06, 2008 | Nokia 3230
Please Unlock my MicroSD password.
I forgot my MicroSd password.Please help me to remove it.I am unable to access my MicroSD card.I have Nokia 6300
Mar 18, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
101 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
