Question about Whirlpool LEQ8000JQ Electric Dryer
Dryer works but does not warm, no gas turn on
  • 3,267 Answers
The heater element is not working. There are no repairs other than the fuse. If fuse is all right, replace heating element
Posted on Jan 03, 2011
MAYTAG GAS DRYER NOT HEATING
That sounds to me like you need to replace the coils. They get intermittent with age. Work some then quit take a long time to cool down and work a little more when going bad.
MY MAYTAG DRYER HOME REPAIR VIDS
Jul 20, 2012 | Maytag Dryers
WGD5530SQO WONT DRY CLOTHES BUT TURNS ON SPINS N DOES NOT WARM UP N GAS LINE FLOWS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 25, 2011 | Whirlpool WGD5900S Gas Dryer
Maytag quiet series 200 electric dryer the dryer turns on and seems to work correctly but does not dry the clothes does not get warm or even hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 28, 2011 | Dryers
Gas dryer turns on, turns, and dries clothes but does not become noticeably hot or even warm.
heatman101
Dec 21, 2010 | Dryers
My firgidaire crown sereis gas dryer heats , turns and get warm not hot
heatman101
Sep 21, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
I have a Frigidaire gas dryer and it ingites and works but with in a minutes the gas is cut off and never ingites back.
On your gas valve , there are 2 coils . Replace both as they come together . When they get warm due to electricity going thru them , one of them will open ( short ) and not let gas come thru until it's cooled down . Turning the dryer back on later , it will work for a short time , then stop heating again until the dryer is cooled back down. Replaceing these coils will solve your problem .
May 16, 2010 | Frigidaire GLGR331A Gas Dryer
The gas dryer does not get warm?
to have it get warm there are 3 things have to be working together:
1- Ignition needs to be on to start the burning.
2- Gas valve needs to be opened after ignition is on.
3- Gas continues jetting in until a thermal switch turns the valve off.
You can open the rear panel to observe if the ignition is glowing or not. If it is not then that the culprit. If it is on then glows off after a while since the gas valve is not open, then you can just replace the thermo sensor if it is separate from the gas controller. Some controller has it integrated then you have to replace that. Good luck.
Apr 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Maytag LSG7806A stackable washer/dryer - dryer not working
Deb, as long as the ignitor is glowing, it's probably your coils on the valve. Look at number 13 and 14 on the attachment. Part number for the booster coil is 306106 and 306105 for the secondary coil. Not a hard job, the coils slide right off after removing a screw and then replace the harness. Catriver...post back.
Oct 14, 2006 | Maytag LSG7806A Front Load Stacked Washer...
Whirlpool LEQ8000JQ Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
