My computer audio work does not work. - Computers & Internet
  • 374 Answers
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (such as Avance AC 97 Audio) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device (something like "AC 97 Audio") should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
To enter BIOS setup turn on your PC and immeadiately hold down the DEL key. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Navigate through the menus until you locate the setting for your on-board sound playback device. If it is set to "Enable" or "Auto" leave it as-is. If it is set to "Disabled." change the setting to "Enabled" or "Auto".
Follow the on-screen instructins to save yur settings and exit BIOS Setup.
If you do not have built-in sound on your motherboard you will need a sound card installed in an expansion slot on the motherboard. This card may not be present. If there is no sound card, install one and then repeat this procedure.
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you will require some help from a qualified PC technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Posted on Jan 03, 2011
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
HDMI audio from computer not working, all updated drivers, Sony STRDH520
Same here... I just bought an external audio plug (Both male ends) and attach it on the computer...
Dec 09, 2012 | Computers & Internet
My audio did not work anymore
If the audio was working earlier and than all of a sudden quit working I suggest making sure that it is plugged into the correct port, than restart the computer and try to play a song than. If it still doesn't work, sounds like your on-board audio card is finished. ALSO make sure your volumes aren't muted.
Sep 06, 2012 | Gateway One Computers & Internet
SPEAKERS NOT WORKING ON MY COMPUTER BUT WORKS ON OTHER COMPUTER
I Think you have an Audio drivers problem.please it whether installed or not.
or
please right click on computer on your desktop.open an computer management window that contains Device manger click it and check whether the audio,video controller drivers are installed or not
Jul 21, 2012 | Audio Players & Recorders
How to install audio device in window xp?
Did you mean install audio device driver? It depends on the manufacturer of your pc. Go to their website, and usually they have available free downloadable audio drivers for the corresponding Operating systems used by their customers.
May 26, 2010 | Computers & Internet
Audio card problem
remove audio card, if computer work shotdown and insert back audio card if machine down, remove and replace that audio card with new one.
Apr 15, 2010 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Reformatted Computer. No Sound.
Looks like you haven't installed your audio drivers.
Dec 27, 2009 | Logitech X-240 Computer Speakers
My i install server 2003,it show a message sigmatel audio driver doesot work properly. i use intel LGA775 motherboard
  • the sigmatel audio driver it is your audio driver not work properly. first thing to do get the installer of your computer or cd driver of your computer. then insert into a cd-rom of your computer. then open the file of the cd driver of your computer then find the installer audio driver. then click the executable file wait until finish to install the audio driver.
Mar 12, 2009 | Computers & Internet
Help!
Hi foxy,
If the speakers do not work, check first that audio is not muted, you find audio settings on Control Panel>>Sound and Audio Devices if there is no audio device , that will need that you have to reinstall the drivers.
If your computer is a brand one (eg Dell optiplex 1080, or IBM Activa etc.) then place a request for drivers on the free forum, giving exact model of your computer.
If the computer is no famous brand, or assembled, you will have to note down all the numbers printed on the boards inside the computer.
That is quite complicate, for a regular user it is often faster to buy a new audio card, that start from $10.
A good solution can be buying an external USB audio adapter , that costs $12 : SIIG SoundWave 7.1 Audio Adapter
Dec 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
