Question about Hunter (25417) Ceiling Fan
Hampton Bay Remote Issues
We have two Hampton Bay ceiling fans operated by their Thermostatic Ceiling Fan and Light Remote Controls.
We find that they have a "mind of their own" and turn on and off in the middle of the night, when we are gone, etc. How can we reset these devices to stay on or stay off? Is there something we accidentally programmed when we pushed buttons that needs to be reset or "un-programmed"?
  • 1 more comment
  • jeanne278 Aug 21, 2008
    We have the same problem. The fan changes speeds by itself and the lights will come on in the middle of the night waking us up. We've changed batteries in both remotes and still have the same problems.
  • cathy55_99 Dec 02, 2008
    Fan turns itself off and on all by itself.. the only difference is I have 2 but they are hunter brand fans.
  • Tomkil Jan 24, 2009
    I have the exact same problem - can anyonehelp?
Having the same problems, only difference is I have it with a Hunter fan.
Posted on Oct 03, 2008
Sounds like some sort of power surge/glitch on that circuit. Is there something on the circuit that cycles on and off that might trigger the fan?
Posted on Jul 24, 2008
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
I have a Hampton Bay Remote Ceiling Fan but Remote is missing. Where can I get one.
1. try ebay
2. stores sell universal remotes that can work most ceiling fans.
Apr 13, 2011 | Universal Remote Control Hampton Bay...
Fan remotes
mcdevito75 here, If the thermostatic switch was controlling another ceiling fan then yes it should work, it"ll have to hook up to the wall switch. I'd double check with a hardware store in the area for more advise.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Dec 08, 2008 | Hampton Bay 52 In. White Redington...
Hunter (25417) Ceiling Fan Logo
965 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
