Question about Kitchen Appliances - Others
Tengo una maquina de hacer pan CBM-018 requiero conseguir el aspa pero no se donde. Pueden ayudarme ya que sin ella no puedo utilizarla.O hay la posibilidad de usarla solo como horno?
SOURCE: un problema con webcam
como puedo hacer mi driver se me a extraviado como mi maquina tuve que formatearla ahora como hago para instalar mi wed cam
Posted on Jun 16, 2008
JSEhandyman
  • 368 Answers
SOURCE: manual de instrucciones y medidas para utilizar la toastmaster platinium 1189s
Hi illinois,
For Toastmaster parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/tm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
yooperbud
  • 8637 Answers
SOURCE: Quickcam logitech version 10.0A
Normal 0 Normal 0 Go to this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System. Then you will get your download driver.
Hope this helps. Bud
Posted on Feb 23, 2009
SOURCE: BUENOS DIAS
hola http://www.creativehomemaking.com/download/Breadman_TR444_Manual.pdf en ese link esta el manual completo en pdf, esta en ingles pero lo puedes traducir facilmente con google traductor, espero haberte ayudado
Posted on Aug 02, 2009
SOURCE: falta instalar " la controladora simple de comunicaciones PCI"
Fijate en esta página que tenes los drivers de las PCCHIPS viejitas. Tenés además, que controlar que el jumper JP3 que habilita la placa de red.
Jumper JP3: Enable/Disable Onboard LAN Use this 3-pin jumper to enable or disable the onboard network adapter.
Function
Jumper Setting
Enable Onboard LAN
Short Pins 1-2
Disable Onboard LAN
Short Pins 2-3
SUERTE!!!!
Posted on Aug 09, 2009
Tengo una venture 98 hace 2 dias la prendi pero en segedida se apago, solo se quedaba prendida cuando apretaba el acelerador pero ahora ya no, ya la lleve con 2 electricos y nada que puedo hacer
Primero checa la precion de la bomba de gasoline y checa si hay chispa en las bujias y si todo esta normal cambia el sensor de pocicion delaselerador y el map sensor
May 11, 2014 | 1998 Chevrolet Venture
No me carga el juego monster world
a un amigo no le carga el juego...le aparece "Bad Request
Your browser sent a request that this server could not understand."...que se puede hacer?.. ya formateo la maquina e instalo todo de nuevo pero no hay caso...por favor espero una respuesta gracias!!
Oct 29, 2012 | wooga - world of gaming Monster World
Hola.. tengo una camioneta dodge caravan 99, 6 cilindros, 3.0, automatica, desde hace tiempo sentia que al momento de meter los cambios se sentia un tiron, pero lo deje y hoy estuvo marchando como de...
hola pues tengo una grand caravan 99 y la palanca de cambio de la caja (automatica) ya no da mas se quedo en D y ya no se puede encender devido a ella que podrian orientarme ?
Jul 07, 2012 | 1999 Dodge Caravan
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
AYUDA! hablemos ingles no quiere funcionar porque me dice que no puede inicializar el servidor del habla. que puedo hacer?
He encontrado la solución.
1-Instalar Hablemos Inglés en el Vista.
Hay que instalar una máquina virtual (Virtual Box por ejemplo), con el Windows XP, y crear una carpeta compartida (la que tenga Hablemos Inglés instalado en el Vista). Se ejecuta el programa desde XP, y se graba una palabra para que inicie el servidor de habla.
2-Se pasa al Vista sin cerrar Hablemos Inglés en el XP.
3-Ejecutamos Hablemos Inglés desde Vista, y empieza a funcionar.
4-Ya podemos cerrar la maquina virtual con el XP.
Es un poco complicado, pero funciona.
Ojo, si utilizas Hablemos Inglés desde el XP virtual, probablemente el sonido de las grabaciones no sea bueno, por lo que hay que utilizar la versión que corre en Vista.
Todo esto es para hacer que se inicie el servidor de habla, y vista pueda ejecutarlo.
Saludos y suerte.
R@in.
Apr 26, 2011 | The Learning Company HABLEMOS INGLES - VER...
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Hola tengo una camara webcam creative live, cambien de computador y no me lo acepta que puedo hacer gracias por tu ayuda
hola melivaob...
aquí tienes un enlace a la página de drivers para webcams de Creative, no creo que el modelo que tienes aparece en la lista principal, pero abajo de todo hay otro link que te lleva a otra página donde puedes elegir entre muchos... pero muchisimos!
a la derecha de la página principal hay un elace encima de los imagenes de los cams que pone 'aprende a identificar su producto'... si la segunda página te parece difícil... vuelve a la primera y siga el enlace para poder saber exacatmente lo que buscas.
lo haria por ti, pero no tengo bastante información para hacer la búsqueda.
espero que eso te ha ayudado, y avisame si tienes alguna otra pregunta...
bru*
Feb 02, 2009 | Creative Labs WebCam Live!
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Un problema con webcam
Jun 16, 2008 | Computers & Internet
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
