Question about Samsung HP-R5052 50 in. Plasma HDTV
50 Inch Plasma Audio Not Working?
My sound went out after a storm passed through...the picture is fine but no sound? Please help. Thanks in advance.
  • 192 Answers
SOURCE: samsung 50 inch plasma
I have found the most common problems with the symptom you have described, to be the SMPS PCB. Sometimes the Y Main will cause the power supply to short out and lower a voltage in that area. Your set has a two year warranty. Call 1-800-Samsung to find an authorized servicer in your area.
Posted on Apr 08, 2007
  • 12 Answers
SOURCE: No picture but have sound on Plasma 50"
Call Associated Electronics @ 414.281.1000 and tell them what you need. They are very good, and extremely helpful.
Posted on Mar 23, 2009
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
  • 458 Answers
SOURCE: i have a 50 inch samsung plasma tv that i think
You would need to purchase a complete new screen as it is not practical or economic to have this done. I would suspect your fault could be a poor connection from the buffer board to that section of the screen or most likely, as you state, the screen is at fault. It is now just as reasonable to buy a new TV than to have the screen replaced
Posted on Jan 10, 2010
Testimonial: "thankyou 4 ur advice, much appreciated "
SOURCE: screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Posted on Sep 23, 2010
Hello, we we have a 50 inch Samsung Plasma TV, from Bestbuy, went to bed and it was working fine, woke up and now we have audio, but NOTHING on screen, completely, black...also tried DVD and same thing,...
Tries tv unplung,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.Tv now 50/50 the tv might work as normal again.If the tv dosen't.Tv have a dead 1 or 2 backlight buffers boards have to be replacing.These 2 long backlight buffers boards only job are to provided a tv plasma screen panel for a backlight to see the picture.Tv now the plasma screen panel have no backlight that why ur tv have only audio sound and no picture.No experience in tv repair and never done any electronic board parts replacement before.Best just call many tv shops and explain the tv situation it in and get the best quote prices for parts and labors.Best prices parts and labors should be around $400 is fair more than that as i said shops around for more tv repair shops.
Aug 19, 2011 | Samsung HP-R5052 50 in. Plasma HDTV
I have a 50 inch plasma and the picture went black but I have sou
You should check the a/v cables, one of the yellow cables is probably broken if not you should get a new cable
Dec 07, 2009 | Maxent MX-50X1 50 in. Plasma Television
No picture on Pioneer Elite Kuro 60" inch plasma
my pioneer pdp 505hd tur on ok but the picture no working and no sound ,can you help me please
Aug 22, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Lg plasma after storm doesnt want to turn on
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PC1DRA 50 in. Plasma Television
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Samsung HP-R5052 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
