Question about Whirlpool Washing Machines
Hi I'm unable to find my washing machine manual.... There is an error message on it saying FE... what does this mean?
  • 472 Answers
This usually is a drain problem either a clogged drain pump or problem with the pump itself...
you will have to gain access to the drain pump and check for obstructions in the hose and or the drain pump ...if not any debri then the pump may be faulty....
Posted on Jan 03, 2011
Error FE on a LG WD 1274FHB what does it mean?
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 15, 2015 | LG Washing Machines
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
My LG WD-85260NP model Front load washing machine is showing the error as 'FE', what does it mean and how to rectify it? I have lost the manual in our transportation and I have downloaded the...
LG's 'FE' stands for 'overFlow Error' which I strongly suspect means a service engineer's attention. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 15, 2011 | Washing Machines
The washing machine displays FE which says a faulty valve can I buy the valve and change it myself
FE is a error signal during fill.For this problem you need to check the water in the tap.If you do this means you can use your washing machine for long time.This can be fixed by you.If your happy with my answer rate me.Thanks for your question.
Jun 22, 2011 | LG Washing Machines
Problem with the Olympus FE-115 Digital Camera my
Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Manuals for the FE-115 are available from the Olympus site: http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1227&fl=8 .
I hope this helps.
Mar 10, 2011 | Olympus FE-115 Digital Camera
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
