Question about Rival S16 Electric Skillet
Do the thermostat contacts attached to bimetalic strip & other strip within plug of the NON-digital Rival skillet erode over time and become thinner? - Friend's skillet (took appart temp. probe plug) has contacts that only touch when dial is set to 300 F or higher, and skillet only heats to appx 100-125 F - No other mechanical problem or abuse seems present, and knob has not twisted on its shaft or become offset; OFF is in proper position when turned "off" etc. Upper (adjustable/moveable one) is seen to move during entire range of knob rotation, just that contacts appear too far appart to meet until quite a high temp is dialed in.
    Problem Solver:
  • 4 Answers
Hate to write answer to my own problem, but after showing (its THAT SIMPLE folks!) the innards to my wife, showing her how contacts do not move close 'nuf together to touch until dialed to 300F, she said, why not put a block under lower stip to raise it. Was about to, when I noted top strip appears to be merely spring steel, and she was advocating propping up the thinner lower BI metalic one, which would have stopped it from flexing as it must as temp of pan changes. SO, we brainstormed it, used her little jewelry needle nose pliers and alternately bent top (spring) strip down and lower (bimetalic) strip upwards with knob set at "warm" until they were TOUCHING, but nevertheless would separate when knob turned fully to "OFF" Since this thermostat pilot light works whether hooked to a pan or NOT, we plugged it in (no danger, probe is not electrified in any way unless maybe handle is dipped in water and salt!) and saw that light goes "on" at warm, off at "off" and further, that when we set it at 200F and hold a lighter under the probe (it is just hollow metal, not a precision device, simply conducts heat to metal strip inside) it turned off properly at what we guess is pretty close to 200F. Will add an addendum "solution" comment when we return thermostat to friends pan tomorrow and cook something!! No electrical degree, just a wife who got tired of me not fixing her firends pan and started unscrewing things until I got aggravated nuf to do something w/ it. Happy New Year. "He who finds a wife finds a good thing." -bible
Posted on Jan 03, 2011
  • Benton Landry
    Benton Landry Jun 23, 2015
    I have just taken apart mine because the probe was loose. But I can't figure out how to fit the probe back in there to fit. Lol
Need replacement electric cord for Rival electric skillet model SS 120
You will be able to locate the nearest authorized parts and service dealer in your are when you visit http://www.rivalproducts.com
Regards.
Jun 05, 2011 | Rival SS120 Stainless Steel Non Stick...
Rival Electric Skillet S16G
Hi, Your skillet is either defective or someone has left it on high with nothing in it. Either way, if it is still under warrenty, I would try and return it. As there is some debate about the toxicity of teflon, I would be very careful about using this unit any further.
If you are going to keep the skillet, try using steel wool to remove the loose teflon, maybe even sanding it all off if you want, then polish with fine steel wool and use the skillet as a regular uncoated electric fry pan.
Hope this helps, and if you found this response satisfactory, please vote. Thanks and good luck.
Mar 02, 2008 | Rival S16SG Electric Skillet
Did not receive the four screws that go into the legs
Interesting. The same gift I got had the screws but not the lid handle.
Jan 06, 2008 | Rival S12T Electric Skillet
Electric Skillet Temp Control Plug
I'm looking for an electric plug for my Rival Electric skillet, where can I find one?
Nov 13, 2007 | Rival S16RB Electric Skillet
Non-stick surface coming off
I find that in viewing this site that the listed " solution" is not a solution at all! This skillet has a defective design and coating and should be recalled!
Sep 03, 2007 | Rival S16RB Electric Skillet
Rival 12x12 electric skillet
it is very dificult to get replacement parts for your electric skillet.but you can try partstore.com and see if they have a replacement part for your skillet.good luck and good cooking.
Jun 08, 2007 | Rival S12-GN Non Stick Electric Skillet
Rival electric skillet # S16g-CN
I have just taken apart the probe / thermostat of this model for a friend. I am an amateur, but it is such an amazingly SIMPLE piece of equipment (in the non-digital, i.e. mechanical thermostat model I'm looking at, that it is clear that the light will be "on" if the thermostat is sending electricity to the heating element, WHETHER OR NOT the element is broken or even connected to thermostat: In other words, if the light is not going on with thermostat knob in any position but OFF, the problem is with the thermostat: The pilot light goes on even if thermostat is NOT PLUGGED INTO the pan; when functioning properly, which one can observe on working pan even w/o taking it appart. But if you have digital model, this will be of less sure use to you, tho the way two yellow wires go to pilot light INDEPENDENT of power returning from pan itself, it suggests the same may be true with all their models.
Nov 29, 2006 | Rival S16 Electric Skillet
Rival S16 Electric Skillet Logo
650 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
