Question about Toshiba CZ32V61 32" TV
My Toshiba CZ32V61 sometimes works and sometimes doesn't. It just suddenly turns black or displays "snow". Sometimes, the red power indicator will flash and sometimes it doesn't. Sometimes the other inputs will work and sometimes they don't. It doesn't seem to have any predictability. Sometimes this happens immediately when turned on, and then sometimes it will work fine for hours. Last week it would not work for four days. This has been going on for several months, but getting worse. Is this worth taking to a repair shop?
    Top Expert:
  • Toshiba Master
  • 75,571 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 05, 2017
  • 196 Answers
SOURCE: Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Posted on Jan 30, 2006
SOURCE: Volume go up to MAX, power button does not work
what is a tact switch and can i change it myself?
Posted on Mar 20, 2008
Dissolu
  • 221 Answers
SOURCE: What year was the Toshiba CZ32V61 made?
Chassis for your TV was bult in 1998 and put into mass production in the 1999. It was used in various TVs for over 3 years. So when it comes to decision wether to invest or not, first try to identify the problem and to estimete the repair costs.
Posted on Jun 29, 2009
villamore
  • 27 Answers
SOURCE: upon powering on my Toshiba 36" I get the normal.......
first of all have a nice day..the problem of your tv is a COLD SOLDER meaning there's only loss solder causing by overheated component such as resistor, tranformer etc. check and look closely to all of the suspected terminals, someting looks burning, try to solder all the susupected terminal using soldering iron and solder. chek also components it maybe cracked resisitor or diodes
Posted on Jul 31, 2009
  • 541 Answers
SOURCE: I have a toshiba 32af43 TV and last night it
Something has gone inside the set. These units have so many safety circuits it is hard to say what section of the set is having problems. I personally start with the horizontal/high voltage circuit because this is the heart beat of the set. Have a repair shop check it out for you. These are good sets and are worth a check out charge. Thanks for using fixya. Hope this helps.
Posted on Nov 09, 2009
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
My toshiba laptop powers on all the time but sometimes there is no display or sometimes it powers on and there is display but all of a sudden i loose display and nothing works.
You have either a lose connection to the computer from the LCD or bad connection inside the laptop on the motherboard. I would remove the keyboard and reseat the cable on the motherboard. Go to Toshiba and download the service manual or go here http://www.eserviceinfo.com/equipment_mfg/Toshiba_43.html
If you are not technicaly inclined do not attempt to repair. Take to a repair shop. Toshiba laptop's are not fun to work on!!!!!!!!
Feb 20, 2010 | Computers & Internet
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
Snow on toshiba 32" tv probably 8 years old
replace sr83 demag relay on main pc board its a 12vdc relay is comon problem with this unit.
Jan 09, 2009 | Toshiba 27AF41 27" TV
32" Toshiba Television suddenly quit working
by the age of the unit it sounds like cold solder connections, on the main board
Mar 27, 2008 | Toshiba CZ32V61 32" TV
Freezing up - shutting off -with stuborn power button also
First clean the fans out - these get clogged pretty easily.
If it gets stuck where you cant turn it off - hold down the power button for 5 seconds.
Hopefully the system hasnt been overheating for so long it has damaged the CPU or motherboard.
If the fans are clean and it still does it, you may have a bad stick of ram or the mainboard you bought may have problems.
I would inform the company you got the mainboard installed that it is having problems right away in case you dont have much time left in warranty.
Dec 19, 2007 | Toshiba Satellite LP154W01 Notebook
Toshiba CZ32V61 32" TV Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
