Question about Toshiba Satellite L355-S7902 Notebook
I want to open the case because the charging port is pushed back.how do i open it up
    President:
  • Toshiba Master
  • 2,246 Answers
Open srew all of it
Posted on Jan 03, 2011
Charging port has pushed inside casing. It is no longer under warranty.
Go to youtube.com and type in the model and manufacturer and look to see how to open the case on your model and you will have too supper glue it back into place, or take in for repair. Takes about and hour too fix.
Sep 20, 2015 | Lenovo B50 15.6" PDC 4GB 500GB
Have to push power adapter hard for tablet to charge
The power port is damaged - most likely the solder joints are loose or broken. You need to find a store where someone can open the case, order the new part for the tablet and then solder the new power port to the board.
Then it will be as good as new.
I have replaced power ports on laptops, phones and tablets.
May 24, 2015 | Tablets & eReaders
How do I open the philips bt3500 bluetooth speaker to repair/replace the charging port?
I opened mine by pulling off the back cover, it is clicked in. then I removed the six screws that appear. Then you can press out the front
Oct 05, 2014 | Audio Players & Recorders
My asus tablet wont turn on
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty.
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.34689589-4d42-4ff6-a950-042de234083f.png
Nov 04, 2013 | ASUS Tablets & eReaders
Google nexus 7 will not power up
Press and hold Volume Down, and then press and hold Power simultaneously until the device turns on.
Hope that helps!
Sep 09, 2013 | Google Nexus 7
My Nexus asus will not turn on even though it be charged over night Had it since Nov 25 2012
You could try to do a hard reset. Press and hold the power button and the volume up button simultaneously for 10-30 seconds and see if the device will then turn on.
Hope that helps!
Aug 05, 2013 | Universal Google Nexus7 7"" Capacitive...
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
Mar 06, 2013 | Tablets & eReaders
Will Not Turn on
Which pin did your husband reposition, I assume it was the one inside the laptop. He may not have connected the power switch cable back in properly when he rebuilt the laptop. Ask him to carefully check all the connections by opening the case again. These sort of repairs are normally carried out by experienced tech engineers. Some dc connectors (the bit that the power supply plugs into) have to be resoldered to work correctly or be replaced completely. The fact that you were able to charge the battery means little at this stage I'm afraid. Let me know if you need more help.
Jun 08, 2009 | Toshiba Satellite M115-S1061 Notebook
Broken Mini-USB Port
This is a very common problem on all GPS systems. The USB port comes loose and disconnects from the motherboard. Sometimes we can re-solder it if it did not come off completely. Sometimes the complete board has to be replaced. I do this all the time for my customers. Your unit must be opened and inspected by a competent repair person (like me) to determine what needs to be done.
Mar 19, 2009 | Garmin nuvi 255W GPS Receiver
Toshiba Satellite L355-S7902 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
