Hello! Are you reading across the pump while the engine is running? If so you are reading the voltage drop across the pump winding...The voltage delivered is +12 volts...Pull the connector to the pump...Read across the plug with the ignition key in the on position...Must read +12 volts..The ground is more then likely resistive and the cause of the dropped voltage... Set the meter to X1 ohm scale...Turn off ignition...Place one probe on the Black wire in the connector...The other probe to bare metal of the vehicle's frame...Must read zero ohms...If not run a braided ground strap from the - terminal of the battery to the chassis is needed...Guru...saailer...
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
That's the voltage of the fuel sender unit, i.e. gas gauge. try the other wires. the power goes on for only 2 seconds so you'll need someone else to turn the key while you check this out
