Question about AEG Dishwashers
I have tried the fix's as described by "Silverdragon" to no avail. The lights on the display still do not light up when switched on.The salt reservoir is empty and the unit has been tipped each and every which way. Regards Murray
  • AEG Master
  • 3,247 Answers
Unfortunately we are not able to see the solutions provided by other consultants. This is how the fixya system is implemented.
Please provide a description of the problem along with a cut and paste of what solution was provided.
Need the full model number of the dishwasher.
Posted on Jan 03, 2011
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
1995 Saab 900 Hatchback, problems with all exterior lights
Wow !! Where to start ??
I think most if not all of the lights go thru the ignition switch. What I mean is the ignition switch must be on for the lights to work.
Most of the lights are on different circuits with different fuses and relays. They are connected to the battery and alternator but not directly. Most but not all are connected to the headlight switch.
One thing that does tie everything together is the grounding of the car. All voltage goes back to the battery by way of the steel frame of the car.
If a ground strap or cable is loose or dirty, electricity has problems getting back to the battery.
So the options are the headlight switch, the ignition switch, and the ground circuits.
I would start by checking the tail lights or headlights to see if they are getting 12 volts, then check and see if the lights are grounded back to the battery. I've even run a wire from front to rear to bypass the car ground connections to test.
Jun 26, 2012 | 1995 Saab 900
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
"A" displayed and will not record caller's message
Your answering machine is set to "announce." In this mode it can announce that you're not available to take the call but will not record a message. The machine automatically switches to this mode when its memory is full.
If the memory is not full, you can switch from the "announce" mode to the "answer" mode by pressing the [ANSWER ON/OFF] button until it lights up in red.
If you need a manual, you may view one here.
Dec 10, 2011 | Sony TAM-100 Digital Answering Machine
The dash lights on my 2006 F150 do not work when the head light switch is in the "automatic" mode. The tail lights do not work when the same switch is in the "headlamp on" position, but...
I would check the grounds for the BODY SECURITY MODULE. I think it is near the back of the cab, behind the driver. There is one ground on the cab panel and the other is on the driver A pillar, probably below dash, behind kick panel. The BSM interfaces witht he Autolamp.
black/light green wire on cab panel and black on A pillar.
Aug 02, 2011 | 2006 Ford F-150
Our Ferguson FRG-CR100D DAB Alarm Clock Radio has lost its digital display - it just shows 16 illuminated blank oblongs in the display panel. It doesn't respond to pressing any buttons, e.g. DAB/Clock,...
Hello
I experienced a similar problem some time ago. I thought I was responsible for the problem because I run the radio of a dual voltage shaver socket and accidentally switched the socket output to 110v. From that point on the radio did excactly what you described. I perservered in trying to find out why but to no avail so I abandoned it. Some months later out of curiosity I plugged it, switched it on and it worked perfectly.
Try leaving it unplugged for a few days (which by this time will have already passed). It may just recover like mine did.
Nov 16, 2010 | Audio Players & Recorders
I dont know if this went anywhere the first time or if I have to pay to get an answer, but I tried to replace the 2 toggle switch below with a switch which had a single toggle switch above a...
It sounds like the outside light may have been wired differently from what you may have thought.
You may need Sparkie to come and comb it through for you. You did not mention what happened to the other switched curcuit that you eliminated.
Lights wire in one of several ways, and the most common run power to the light and then on to the switch. in this configuration, the white neutral wire should be taped black, as it carries hot power during use. This wiring configuration may not allow you to have a power plug as you describe, as there may not be full time power in the switch box.
the other most common is power comes to the switch and then on to the light. this is much less commonly used.
Nov 06, 2010 | Pass & Seymour #690WGCC6 15A White 2SP UL...
Dishwashers Logo
60 people viewed this question
Top AEG Dishwashers Experts
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
