Question about Kitchen Ranges
Wireing diagram from pressure switch to pump control
  • Kitchen Ranges Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Jan 03, 2011
Fuel control module 2008 escalade and the fuel pump quit working.if I run a hot wire to it it will run but as soon as I remove the hot wire it quits
Ran a hot wire to what fuel pump or the control module ? Which of these is yours ?
Figure 9: Fuel Controls - Fuel Pump Controls (LY6)
Figure 10: Fuel Pump Flow Control Module (Except LY6) Does yours have fuel pump flow control module under the vehicle Fuel Pump Flow Control Module (except LY6)
Mounted to the left side of the frame assembly below the driver seat ?
Fuel Pump Flow Control Module (FPCM) - LMF
The fuel pump flow control module (FPCM) is a serviceable GMLAN module. The FPCM receives the desired fuel pressure message from the engine control module (ECM) and controls the fuel pump located within the fuel tank to achieve the desired fuel pressure. The FPCM sends a 25 KHZ PWM signal to the fuel pump, and pump speed is changed by varying the duty cycle of this signal. Maximum current supplied to the fuel pump is 15 amps. A liquid fuel pressure sensor provides fuel pressure feedback to the FPCM.
Electronic Returnless Fuel System (ERFS) - LMF
The electronic returnless fuel system is a microprocessor controlled fuel delivery system which transports fuel from the tank to the fuel rails. It functions as an electronic replacement for a traditional, mechanical fuel pressure regulator. A pressure vent valve within the fuel tank provides an added measure of fuel pump flow control module (FPCM). Desired fuel pressure is commanded by the engine control module (ECM), and transmitted to the FPCM via a GMLAN serial data message. A liquid fuel pressure sensor provides the feedback the FPCM requires for Closed Loop fuel pressure control.
If your vehicle has this system check it for DTC'S - diagnostic trouble codes . Will take guess work out of it .
DTC P0191: Fuel Rail Pressure (FRP) Sensor Performance
DTC P0192: Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
DTC P0193: Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
DTC P0230: Fuel Pump Relay Control Circuit
DTC P0231: Fuel Pump Control Circuit Low Voltage
DTC P0232: Fuel Pump Control Circuit High Voltage
DTC P023F: Fuel Pump Control Circuit
The engine control module (ECM) supplies voltage to the fuel pump flow control module (FPCM) when the ECM detects that the ignition is on. The voltage from the ECM to the FPCM remains active for 2 seconds, unless the engine is in crank or run. While this voltage is being received, the FPCM supplies a varying voltage to the fuel tank pump module in order to maintain the desired fuel rail pressure.
DTC P025A: Fuel Pump Control Module Enable Circuit .
Ford Electronic Returnless Fuel System Diagnosis Part 1 this for ford but the GM system works the same . You'll need a wiring diagram so you know what wires are what . Free wiring diagrams http://www.bbbind.com/free_tsb.html
Oct 31, 2016 | Cars & Trucks
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I need a gmc safari diagram for fuel pump 1991
I don't usually do diagrams due to copyright laws.
From the fuel pump you have a gray wire and a black wire.
The black is ground and the gray is power from both the pump relay and the oil pressure switch.
The oil pressure switch provides power to the pump once the engine starts.
At the relay, you have a green and white wire that provides power from the ECM with the key switch on. You have an orange wire that provides power from a 15amp fuse.
The gray wire going to the pump, and a black and white wire for ground for the relay.
The ECM provides power for 3 seconds when the key switch is turned on to boost line pressure for startup.
Jan 30, 2013 | 1997 GMC Safari
Fuel pump wiring diagram for 2001 chevy S10
The harness is a dealer part or a scrapyard part. The harness itself for jsut the fuel pump as it is set up by GM- the relay coil has one side hot +12 volts all the time, even when off. The ground side of the coil goes to the 3 bladed oil pressure switch which completes the ground circuit when there is oil pressure This is the tan wire.
There is a wire that comes from the ECU to prime the pump and keep it operating while initially starting. This is usually a white wire.
+12 volts usually is applied at all times at cavity 87 in the relay connector and the wire to the fuel pump is in 87A.
The harness from the dealership will list price at about 2000.00 US, and it will be the entire harness that includes that portion for the fuel pump.
If your pump is not energizing, or not staying energized, the oil pressure switch is likely at fault. By the same token it stays energized all the time unless relay is disconnected.
If you are going to add a switch, the easiest thing to do is gut out an old fuel pump relay and solder to the contact parts and clip the relay coil. This does bypass all auto shutoff. The wire will see some fair current so use 12 gauge or 10 gauge.and keep run as short as possible.
Feb 06, 2012 | Chevrolet Cars & Trucks
I need a wiring diagram for a 1998 Chevy Blazer fuel pump
The fuel pump assembly consists of fuel pump relay,fuel sensor,the fuel pump controlling fuse,its ECM B fuse. The fuel pump and oil pressure switch. ----------- For its wiring diagram, click the link below and refer the diagram:--- http://technoanswers.blogspot.com/2011/10/fuel-pump-wiring-diagram-for-1998-chevy.html ----------- This should help.Thanks.Helpmech.
Oct 06, 2011 | 1998 Chevrolet Blazer
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    NEED INSTALLATION INSTRUCTIONS.
    Hi and welcome to FixYa, I am Kelly
    The wiring diagram is on or inside the cover.... However, it is better to see it in a video.
    This video is for a Square D switch but the procedure is exactly the same:
    http://www.youtube.com/watch?v=ggn0hyGI2AU (same as below)
    Just remember when it comes to pressure adjustments if needed that the big sprong is for HIGH pressure shut-off and the small spring is LOW pressure pump start adjustment.
    2 power wires in for the power supply and 2 wires out for the pump to run.
    Thanks for choosing FixYa,
    Kelly
    Apr 16, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
    My pump builds pressure to 60 psi but will not go any hire for the shut off what can be the problem
    most jet pumps have a pressure switch to regulate cut in/ cut off pressure. Normally 40/60 psi. The pressure switch should be located at the rear of the pump where the wiring enters. First disconnect the power supply to the pump. Remove the cap where the wiring enters. On the inside of the cap there should be a diagram showing how to alter the cut in/ cut off pressure.
    Jun 13, 2010 | Jet Plumbing
    Wiring up a pump with capacitor and pressure switch
    This is a confusing explination of your problem. Elect is dangerous and should be left to profectional's
    Jul 02, 2009 | Pool & Spa
    Kitchen Ranges Logo
    42 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
