Question about Brother LS-2125 Mechanical Sewing Machine
My sewing machine makes whirring noises but will not sew anything (the needle will not move)
  • 30 Answers
Not sure about this model but most have a belt inside the machine to connect the motor to the rest of the machine. Some have an access plate you can remove. New belts are available many places and are usually easily replaced. Good luck
Posted on Jan 03, 2011
  • natsi_pony_b Jan 03, 2011
    It makes the sound like it normally does when it sews but nothing happens, anymore ideas?
White Sewing machine won't start. Makes the whirring noise but will not advance fabric. I've tried moving the bobbin spool back and forth but it still won't start.
If your machine is not broken, it most likely is seized due to old oil that has hardened. How long since its last service? Refrain from trying to run the machine until the issue is resolved as it could damage the motor. or more...
Wheel on right side that controls the needle up and down is very tight...
Aug 29, 2017 | White Sewing Sewing Machines
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
Needle no longer moves up and down but the engine whirs
sounds like the needle is bent replace the needle
Dec 25, 2013 | Sewing Machines
The thread isnt moving with the sewing machine
is it possible that you didn't get the needle inserted all the way into
the needle holder?
is it possible that the needle is not turned the right way in the
needle holder?
Oct 27, 2012 | White Sewing Sew Cute SC20 Mechanical...
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
Needle touches a metal part and makes a weird noise!
you could have your needle in backwards-- thats been the problem when mine did that
Mar 14, 2008 | Necchi 3102 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
273 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
