Question about Car Audio & Video
My battery kept draining overnite in my 1998 ford expedition.now the radio stopped working and now the battery holds the charge just fine.i pulled the radio and checked for power,i am getting 12v out of the red wire but the radio will not power up.i also tested the radio it works fine what could be the issue please help
    Scholar:
  • 85 Answers
It sounds like you might have a bad or loose ground to the radio when you install it in the car. Where did you test the radio to verify that it worked?
Posted on Jan 03, 2011
Turned radio off then battery died, got vehicle fixed but no power to factory radio, all fuses check as good. Is there a trick to getting the radio to turn on again?
when the battery dies or is removed , the anti-theft code of the radio kicks in and the unit will not work again until a special code for that radio is reinstalled
the code could be in the user manual in the radio use section ,or there are sites on the net that may have the code for you
Mar 24, 2016 | 1998 Ford Expedition
My 1999 ford expeditin wont hold a charge i ve replaced battery and alternator and voltage regulator
hold a charge when, and stop guessing, please !
state when
and under what conditions.
here, are some simple examples.
car battery drains as i sleep (phantom drain, dark current)
car battery drains, as I drive.
battery will not hold a charge battery sitting on my work bench.
just 1 clue?
this is all easy, to fix. and find. post the full symptoms.
Oct 26, 2013 | Easy Quick Auto Jumper Recharges Vehicle...
CONSTANT DRAW IS DRAINING BATTERY
sounds like you know what you are doing...
Kudos for at least trying to fix it yourself anyways!
Charge the battery and sell it... lol
Mar 28, 2013 | 1998 Ford Expedition
Battery on 98 Ford Expedition doesn't hold charge
First thing I would do is have someone qualified disconnect the alarm and stereo and start over.
Chances are you have circuits cross-connected and something is draining the battery.
Jan 14, 2013 | 1998 Ford Expedition
Where is the powerlock relay located on a 1998 ford expedition eddie bauer
The Aux. Relay Box #4 is located in the rear driver side removable panel with the jack. The box holds the Door lock and unlock relays; The driver's door lock/unlock relay and the ACC. Lights relay.
Jan 10, 2011 | 1998 Ford Expedition
1998 expedition wont start
check if you have power at the starter solnoid if so you may need a starter
Jul 08, 2009 | 1998 Ford Expedition
Draining battery trouble starting
Check fuel pressure should read at least 30psi at the rail with no start. Or you can listen for the fuel pump to kick on when you turn the key. You should hear a high pitch sound if you don't you probably need a fuel pump and filter. How many miles on truck?
Jun 16, 2009 | 1998 Ford Expedition
Battery is draining
have your stater solonoid checked out it may be shorting out inside
Oct 10, 2008 | 1997 Ford Expedition
I have an electrical, problem the battery is being drained overnight and i can't seem to find out what is causing the problem ,any ideas?
start with battery. sometimes older batt. won't hold a charge overnite. disconnect battery and reconnect next day and check. if batt is ok disconnect alternator overnite and connect next day to see if it was problem.
Aug 12, 2008 | 1997 Dodge Stratus
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
