Question about Toshiba TheaterWide 62HM94 62" Rear Projection HDTV
Toshiba 62hm94 Turn on, get picture for 10 sec, then goes away sound is still ok the bulb is still lit, but screen is blank. I think it has to do with heat.
  • 50 Answers
I think the lamp is bad. If you are able try a new lamp.
Posted on Jul 09, 2008
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Toshiba 57H81 57 in. Rear Projection Television - Red Picture
Watch out for anything that has maginets around the area,try that and if it don't work ask again.
May 27, 2010 | Toshiba 57H82 57" Rear Projection...
I turn the TV on. Then about 3 minutes later the picture goes out but the sound is fine. I turn the TV off, then back on. The picture returns only to cut off againg.This happens when viewing the in TV mode...
When picture goes away do you see the screen still emitting light or does it go completely blank?
Depending on the answer there are two possiblities:
if the screen goes completely blank then the problem is likely in the TV's inverter and more specifically very likely in some of the high-frequency transformers. Best solution there is replacement.
Unfortunately inverters are often on one board with power in smaller TVs.
if the screen is still emitting light albiet being blank then the problem is more likely in the main board and, less often, in a cable.
Main boards often overheat and ICs relying on soldering contact bonds of 1/10 sq.mm. start misbehaving in all kinds of ways , including like you describe.
There's no simple cure for that problem - usually it's cheaper to replace the whole board or even the whole TV than to troubleshoot it.
Perhaps not great news, but that's what I know about it.
Bobby
http://www.coppelltvrepair.com
Jan 23, 2010 | Toshiba 20HLV86 Television
Gives picture for 10 secs then goes blank,although i can still see graphics on the screen slightly,turn on and off gives picture again then goes blank
There is a problem with the LCD Panel backlight - Check to see if your monitor is still covered under warranty and get it replaced under that....
Aug 06, 2009 | Xerox Computers & Internet
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Buzzing sound in front of Toshiba 62HM94
Hey buddy the lamp is good hopefully havent pop yet but i suggest you dont continue powering on turn it off and call your local tech service guy the problem your having is your power supply and the balus you need to replace thats the buz noise your getting here is a local tehc athorize toshiba cecnter to help you with that in van nuys ca 818-785-8085 or go to toshiba site and get the closes to you.....
Oct 30, 2008 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62hm94 projection tv
Sounds like the lamp is going bad. They heat up, and shut down. Then when they cool off they start back up.
Jul 09, 2008 | Televison & Video
Bulb removal
All you do is remove the screws from the panel in the back and pull the bulb assembley out.
Aug 13, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba TheaterWide 62HM94 62" Rear Projection HDTV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
