Question about HP Pavilion ze4115 Notebook
My girl stepped on the notebook when it is running, then it fails to power up, what can I do now?
  • HP Master
  • 3,247 Answers
It is likely the lcd display has cracked or dislocated. Try connecting a normal vga monitor to the monitor port and select the external monitor from the keyboard using the F4 key or whatever function key has the display symbol.
If the LCD is the problem you should be able to run from the external display.
It is then a matter of replacing the lcd display or continuing to use the external display. A new lcd will set you back about $200 to replace.
Posted on Jan 03, 2011
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
Tip
Limited or No Connectivity
<b>Hardware works but wireless doesn't and you're getting the limited or no connectivity error.</b><br /> <p><b>Please note:</b> This document assumes that you have checked that the wireless NIC is turned on and that the Wireless Service and DHCP Service have been checked and that they are both enabled on the notebook and the services are running.<br /> <b>If you're unsure about the services do the following:</b><br /> 1. Start &gt; Run &gt; 'services.msc'<br />2. Search for DHCP Client in the services list. The Status should be Started and the Startup Type should be Automatic. If not, right click on the service choose properties and fix the Startup Type to Automatic. Click OK to close the window.<br />3. Search for Wireless Zero Configurations. The Status should be Started and the Startup Type should be Automatic. If not, right click on the service choose properties and fix the Startup Type to Automatic. Click OK to close the window.<br />4. Close the window<br />5. If you had to restart any of the services, reboot the computer.<br /> <b>1. Update wireless driver</b><br /> Boot the computer into safe mode with networking.<br />Hardwire the notebook to the cable/DSL modem,<br />Uninstall the drivers and utilities for their wireless card.<br />Customer should go to the manufacturer's website and download the latest wireless driver revision for their notebook.<br />Install the latest driver.<br />Shut down the computer and unplug the LAN connection.<br />Reconnect the router and modem.<br />Wait for router and modem to sync.<br />Boot the computer again.<br />Test the connection.<br />If the connection fails go to step 2.<br />If the connection works resolved.<br /> <b>2. Winsocks fix</b><br /> <b>Start &gt; Run &gt; 'cmd'</b> enter<br />Type in the following:<br />netsh winsock reset<br />Computer should need to be rebooted<br />Test computer after reboot<br />If the connection fails go to step 3.<br />If the connection works resolved.<br /> <b>3. Power cycle the router</b><br /> Unplug the router and let it sit for 30 sec.<br />Power down the notebook.<br />Plug the router back in and wait for all the lights to stabilize<br />Reboot the computer.<br />After the computer makes it to the desktop test the connection.<br />If the connection fails go to step 4.<br />If the connection works resolved.<br /> <b>4. Confirm that the connection is set to b or g (depending on router)</b><br /> <b>Start &gt; Right Click 'My Computer' &gt; Manage &gt; Device Management &gt; Network Connections &gt; Right Click on the Wireless NIC &gt; Properties &gt; Advanced Tab</b><br />Click on Wireless Mode under property<br />Make sure that it is 802.11g or 802.11b depending on the router.<br />If the connection fails go to step 5.<br />If the connection works resolved.<br /> <b>5. Move the notebook closer to the router (within 3 feet or less).</b><br /> In some cases the antennae may be damaged or disconnected from the Wireless NIC.<br />Verify that the wireless antennae are connected to the wireless card by going under the panel and looking for them.<br />If the connection fails go to step 6.<br />If the connection works resolved.<br /> <b>6. Check for encryption</b><br /> If encryption is there can it be cleared?<br />Y. Clear settings<br />Hard reset the router (usually involves holding down the hard reset button for 30 sec and having the router go back to default settings).<br />Disable encryption keys on the notebook.<br />If the connection fails go to step 7.<br />If the connection works resolved.<br />N. Do following<br />Hard reset to factory default (to clear any configuration setting that the customer may have set up).<br />Insert the WEP/WPA key using generic setup (on connections)<br />If the connection works resolved.<br />If the connection fails - go to advanced setup<br /> <b>Advanced Setup:</b><br /> <b>Go to Start &gt; Control Panel &gt; Network Connections &gt; Right Click on Wireless &gt; Properties &gt; Wireless Networks &gt; Click on //Network Name// &gt; Properties<br /></b>Select WPA-PSK<br />Set Data Encryption to TKIP (if not already selected)<br />Enter Network Key (confirm case of letters)*<br />Confirm the key<br /> Click OK<br /> *Note: copy and paste does not always work ... type the key in manually!!! (garbage characters can exist in a copy and paste or spaces may appear!!!)<br />Test the connection:<br /> If the connection fails go to step 7.<br />If the connection works resolved.<br /> <b>7. Mac Filtering</b><br /> Hard wire the notebook and verify that MAC filtering is not enabled on the router.<br />If it is disable the filters and test the connection.<br />If the connection fails go to step 8.<br />If the connection works resolved.<br /> <b>8. Verify Channels</b><br /> <b>Start &gt; Right Click 'My Computer' &gt; Manage &gt; Device Management &gt; Network Connections &gt; Right Click on the Wireless NIC &gt; Properties &gt; Advanced Tab<br /></b>Under Property choose Channel <br />Make sure that the Channel is the same as on the router.<br />If unsure:<br />Connect via LAN to the router and look up the channel that it is using.<br />If the connection fails go to step 9.<br />If the connection works resolved.<br /> <b>9. Disable Firewalls</b><br /> Check to make sure that the firewalls are disabled. In some cases these can interfere with connections being made to the router. <br /><b>Start &gt; Run &gt; MSCONFIG</b><br />Disable all startup items<br />Reboot the computer<br />Test the connection.<br />If the connection fails:<br />Uninstall all firewall software and disable the XP firewall.<br />If the connection works resolved.<br /> <b>10. Router firmware update</b><br /> Conference in router manufacturer and explain the issue and tell them WHY an update is necessary (no communication between router and notebook).<br />
on Mar 15, 2011 | Computers & Internet
Tip
Wireless - Limited or no Connectivity
Hardware works but wireless doesn't and you’re getting the limited or no connectivity error.
Please note: This document assumes that you have checked that the wireless NIC is turned on and that the Wireless Service and DHCP Service have been checked and that they are both enabled on the notebook and the services are running.
If you’re unsure about the services do the following:
1. Start > Run > ‘services.msc’
4. Close the window
2. Winsocks fix
Start > Run > ‘cmd’ enter
netsh winsock reset
Start > Right Click ‘My Computer’ > Manage > Device Management > Network Connections > Right Click on the Wireless NIC > Properties > Advanced Tab
Y. Clear settings
N. Do following
Advanced Setup:
Go to Start > Control Panel > Network Connections > Right Click on Wireless > Properties > Wireless Networks > Click on //Network Name// > Properties
Select WPA-PSK
Confirm the key
Click OK
*Note: copy and paste does not always work … type the key in manually!!! (garbage characters can exist in a copy and paste or spaces may appear!!!)
7. Mac Filtering
8. Verify Channels
If unsure:
Start > Run > MSCONFIG
Reboot the computer
on May 25, 2010 | Computers & Internet
I forgot my password HP 650
Try restarting the computer using Safe mode or Last Known Good Configuration.
Step 1: Turn Off Computer.
Step 2: Power it back on, as soon as you press the power button, keep tapping the F8 button on your keyboard (donot hold it down) until you get a black screen.
Step 3: Select Last Known Good Configuration.
If that fails, Follow step 1 and 2 then select Safe mode.
If that does not work, you will have to reinstall Windows using a Windows Operating Disk (In this Case you will lose all the data that is in your C:/) Drive.
Nov 20, 2013 | HP 650 Notebook PC
02 vue was hard to start , then wouldnt changed cam and crank sensors and found fuel in the oil. now runs for ten minutes and dies wont re start have 9 codes all having ecm in common replace that next
WHOA COWBOYS AND GIRLS!!!
CHECK VERY CAREFULLY ALL PIN CONNECTORS AT ECM POWER PLUG FOR PROPER CONNECTIONS, BENT PINS ETC....
ECM'S DO NOT FAIL TOO OFTEN!
Feb 23, 2013 | 2002 Saturn VUE
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Is there a reset button to start the power on the computer? When I push the power on button, the computer does not turn on.
You can try a couple of steps before.Romove the battery only and try to start it with just the AC only.If this fails try step two.Remove the battery and the memory.Press and hold the power button down for twenty seconds.Replace them and try again.Step three remove them again,this time remove the hard drive and the cd romas well as the battery and the memory.Press and hold the power button down for twenty seconds again.If this fails chances are the motherboard needs to be replaced.
Good luck
Oct 22, 2009 | Dell Inspiron B130 Notebook
Replacing the screen on an HP DV2040TX notebook computer
http://www.lcds4less.com/laptop-lcd-removal-instructions.shtml
Jan 01, 2009 | HP Pavilion dv2000t Notebook
Stuck in standby
Have you held down on the power button for more than 10 seconds to be sure the unit is off?
If not unplug power cord and remove battery if all else fails
Nov 23, 2008 | Compaq Armada M700 Notebook
Battery
AC only will not effect speed what so ever, running on battery only does. Battery only decreases the speed, it's the speed step technology to make the battery last longer. If a fail safe in the battery engages, it could effect the machine's performance, so if you see any decrease in the performance, remove the bad battery and run without it.
Aug 29, 2008 | Dell Latitude D600 Notebook
HP Pavilion ze4115 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
